Sold/Expired Custom 750 HP Mega jeep
fab-werx
New Member
Engine
468 CI Big block chevy 9.5 to 1 compression (pump gas)
Eagle rotating assy w/ARP bolts
Custom grind cam shaft
Brodix aluminum heads (flowed)
Aluminum crower 1.72 rockers
BDS 871 blower w/fuel injection (16-40# injectors)
Custom aluminum radiator (twin elec fans)
Accel and MSD ignition (with laptop for tunning)
Custom headers and mufflers
(Note blower drive is d-tuned to 6 pounds of boost for running pump gas can
change pulleys and produce more power)
Drivetrain/suspension
Custom 4 link suspension
Turbo 400 (built by Monster transmissions)
Atlas 2 transfercase w/1410 yokes
2.5 ton axles (Overson engineering built w/lockers and selectro hubs)
Big shocks on all 4 corners w/Diest limit straps
Chop fab 1"sway bar
Wilwood brake system
Full hyd steering
New 49" Iroks on custom rims (un cut)
New 19x24 Good yeae r2 with custom rims
Body/Interior/exterior
Custom metal work on tub
Line-x coating on all sheetmetal and interior parts
Custom seats w/5 point harnesses
Back seat has 5" lap belts
Custom 6 point cage
Custom bumpers
RCI 15 gal aluminum fuel cell
Cold blowing A/C (for those long trails)
Autometer gauges
B&M shifter
Everything on this jeep is quality made or name brand it has only been out 3 time once to louisiana mud fest and the other 2 times to local mud hole
Wanting to build something elese so no trades
You couldnt build it for what im asking for it
Asking $25,000
Im located in central florida you can reach me at 863 528 7797
Bronco Buster said:
Just reply to the post and add more each time. Just like you did when you ask this. You are only allowed 1500 kb per post
Also use Photobucket and then you can post as many pictures as you want and don't have to worry about picture size.
ttt
bring that big ***** back down to earth and get rid of the "big shocks" and that damn thing would be NASTY..and add a good cage
