Sold/Expired All Toyota Mo-Fab buggy
Brian Brown
mo fab chassis.All toyota dual case,22re,5speed,aluminum links 7/8 himes,dual fan radiator,14" fox coil overs,32 bolt bead locks,corebu seats, 37" stickies.112" wheelbase.everything is brand new but driveline and tires.tires r about 90%. It is a roller right now. It was built to also hold a small if someone wanted.. $13,000.daylan 615 5663497i can send pics if someone wants them
Posting this for a friend!
Guys I listed this for him because he doesn't get on here so call the number in the add of just post up here and I will do my best to answer all your questions. It is a a fuel injected 22re complete but his thoughts were propane for ease of wiring but can go either way at this point. Stock dual cases with marlin adapter, longfields,marlin hysteer, ifs hub conversion to match rear axle width, I will try and figure out a little more on the details and clean this post up I know it has some sort of lockers and I am pretty sure 5:29 gears
Top will be a bad boy finished for sure wide enough for other drive terrians as well!
