Sold/Expired Built 2000 TJ
KrawlerTJ
Member
I've found something else I want, so I'm putting the TJ up for sale. If the other one sells before this, then I will be taking this down and keeping it.
2000 TJ approx 65,000 miles
I-6, NV 3500, 231 w/ SYE
Front Axle:
HP 44, 5.13's, ARB, BTF cover, has stock shafts in it now, but have long side yukons for it.
Rear Axle:
LP 60, 5.13's, ARB, BTF cover, Disk Brakes, 35 spline semi float axle (has spares)
Suspension:
4-linked front and rear. Wheel base stretched to 100".
Dual rate remote resivor Sway-A-Way coilover on all 4 coners
Rear frame is tube from front seats to rear (Tube work done by Jim's Garage)
Front is a combination of Liquid Iron hoops, Ruff Stuff Track Kit, Custon Truss, Clayton Brackets.
Body/Cage:
Front tube fenders are Poision Spyder as are the rear Comp corners.
Rockers are custom to fille the gap from front wheel opening to rear corners.
Cage was built by Andy at Carolina Rock Shop. It's a CJ style cage, Tied to the frame 6 points, seats are also tied to the cage.
Stock tank is custom made box in rear cargo area.
Tires:
37" Red Label Krawlers
**Winch and PowerTank are NOT INCLUDED**
Pics are much easier than words. I'm sure I'm forgetting stuff, so take a look.
Asking $12,500
If you want more information shoot me a text at 276-733-1742.
Some of these pics are older than others, but the last one on the trailer is pretty much how it sits right now, except I have painted all the new front suspensions stuff. I have plenty more I can send if you want something particular. Dates on some of the pics are not correct.
Jeep is currently located at our house in VA, but I can get it to the Charlotte area pretty quick (or anywhere along I-77 between Charlotte and Fancy Gap)
