Hardline Crawlers
August 21, 2019, 05:53:40 PM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News: Check out the Calendar for all upcoming rides and competitions.
   Home   Help Calendar Login Register
Pages: [1] 2 3 4 5 6 7 8   Go Down
  Print
Author Topic: 75-95 Toyota Parts for sale - Garage Spring Cleaning, I ship, Paypal Amazon pmts  (Read 59509 times)
Erick561
Offline Offline
Online Toyota Truck Dismantlation Vendor in CT
WWW
« on: May 20, 2014, 07:39:48 PM »
I have parts left over from my build and need to downsize. I had to obtain and maintain two vehicles for several years but I took too much on so now I'm liquidating.  I like to fix these trucks up and parts are becoming harder to find so I don't want these to go to waste.
$100 pair of  Truck IFS 4X4 AISIN Manual Locking Hubs 86-95 4Runner
 Truck Pickup Pedal Assembly Clutch Brake & Gas PEDAL 84-88 89 4Runner $30
 Truck Heater Core & Box 84-88 89 4Runner $40
 Truck Transmission + Transfer Case W56 4WD Forward Shift 5spd 86-88 mechanical speedo $250
 Truck g54 Transmission + Transfer Case 4WD Forward Shift 5spd 84-89 $280
 Truck Transmission + Transfer Case W56 4WD Forward Shift 5spd 92-95 digital speedo $160 tcase sold
 TRUCK 4RUNNER 22R 22RE EXHAUST DOWN PIPE $40
84-88 Pickup 4runner 22R Air Box B/O
OEM 84-88 Small  Emblem OEM 75351 89119 Truck 4 Runner $10 each
84-89  4RUNNER TRUCK PASSENGER DOOR HINGES top bottom $15
 Celica Windshield Wiper Motor OEM 82-85 $25
 TRUCK GAS PEDAL 84-89 $10 3 available
84  Celica Power Steering Reservoir, Hard line and Hose 67941 82-85 $40
84  Celica GT 22RE Gas tank float, complete $70 obo
1979-1983  Truck Hood Latch $15
 Hilux Truck SR5 4wd Instrument Cluster Gauge Panel Speedo Tach 79-81 $60 Round plug
 truck 2wd Manual Steering Box + Mount *Eliminate Power Steer* 84-95 dragrace $50 reduce drivetrain drag increase HP sold
 Mechanical Fuel Pump for 22r 20r Truck 4Runner Celica $20
82 83 84 85 86  CELICA SUPRA HEATER CORE $30
84 85 86 87 88  PICKUP HEATER CORE STD SPEC $30
1984  Pickup pedal assembly $20
 Truck 4x4 Front inner wheel well plastic liner panel 84-89 4Runner $20 LH RH
1982-1985  Celica GT chrome "CELICA" and "GT" logos $25 each
82-85  Celica/Supra Radio Stereo Pocket Storage Cubby Trim Dash Kit $15
 Truck Front DriveShaft V6 4X4 88-95 90K LOW Miles $40
 Truck Hood Hinges Blue or Red 84-89  4Runner $25
84-88  Truck Windshield Wiper Linkage Mechanism $20
Pickup Interior Door Molding Blue Grey 84-89 4Runner $30
 Truck Seat Belt Left Passenger Side 84-89  4Runner $15
 Truck 22re AC Compressor, Clutch 4Runner Celica Corona No Bracket $35 unknown miles recharge
79-83  Hilux Pickup Truck Rear Drive Shaft 4x4 SWB Short Bed $80 SOLD russ
1979-1981 Black  Hilux Pickup Grill 4x4 with Emblem $40 SOLD
? Truck 4.88 8" 4X4 Diff Gears Complete 3rd Member 79-95? $300 SOLD
84-88  Truck Door Jamb Blue or Grey Scuff Plates Carpet 89 4Runner $30
? Truck Windshield Trim Panel Cover Cowl No Rust 84-89 4Runner? $40
 Truck Power Brake Booster w/ Master Cylinder 4Runner Pickup 84-95 $50
 Truck EMISSION CANISTERS 22R Fed 77740 35260 84-88 i think i sold it obo
 Truck Windshield Wiper Motor 4Runner 84-89 $20
$40 Pickup 4Runner Front Drive Shaft 4X4 22R 86-95
$60  Truck Manual IFS 4x4 Steering Box 86-1995 PS Delete Drag PreRunner SOLD russ
 AM/FM Radio 1423 Pickup Camry 4Runner Celica Supra $10
89-95  Truck White repainted Tailgate with Blue  logo $40
79 80 81 82 83  Hilux Pickup Truck IC Regulator $20
84-89  Truck Speedo Cluster Instrument Panel Pickup 4Runner $25
 truck cab side ventilation vents (drivers + passengers) 84-88 $20
? Truck Instrument Cluster Bezel Grey ?84-89 LED alarm light $40
 Truck Grey Radio Bezel Trim 84-88 Pickup $30
86-88  PICKUP TORSION BARS 68225 68227 $150 Pair comes with female couplings
1975-95 20r 22r 22re  OIL PAN 4RUNNER TRUCK 2WD $40
1979-95 20r 22r 22re  OIL PAN 4RUNNER TRUCK 4WD $40
82-85  Celica H/B GT A60 License Plate Garnish $35
?Original  Celica GT Black Grille w/  Emblem 82-85? $35
 Hilux Pickup Truck 20R AISIN CARBURETOR, Celica Corona $70
 PICKUP DISTRIBUTOR 22RE 86-95 $75 SOLD
 Truck Lower Dash + Heater control panel and cables combo -ac Blue 84-88 $50
 Truck Blue, Grey Dash Trim w/ Dimmer 84-88 $25
 Hilux Front Frame clip 4x4 IFS Delete SAS Truck as pictured, save time! $70
 Pickup 84-88/89 4Runner Blue Front Clip with half the fenderwells $40
84-88  Truck Tail Light Assembly with 22R tail light harness including wired in trailer hookup and reverse lights $60
$120  Truck Custom Grill Guard Winch Mount with Chrome Front Bumper 4x4 84-89
84-88  Truck Side Marker Light Drivers side 89 4Runner $15
84-88  Truck Side Marker Light Passengers assembly 89 4Runner $15
 Celica Complete Driveshafts + Carrier bearing 82-85 2-Piece $120
$10  Truck Right Side Fender Blue 84-88 trim for clearance big tire rockcrawl
$10  Truck Left Side Fender Blue 84-88 trim for clearance big tires rock crawl
$20  Truck 2wd 84-88 Red Drivers side fender small dent
 Truck Crossmember Trans TCase 4x4 Pickup 4Runner w/ mount $40
84-89  Truck Ignitor Coil 22R Carbed $70 SOLD
OEM  Hilux 4x4 Power Steering to knuckle arm Drag Link $40
OEM  Hilux 4x4 Sway bar 1979-1985 $50
79-85  Hilux Steering Knuckle Arms $200 SOLD
79-95  Truck Power Steering Pump 20r 22r 22RE with bracket pulley $40
OEM 79-85  Hilux 4x4 Tie rod with Aftermarket Dual Stabilizers + Dual Stabilizer Mount from NWOR $100
 Truck Blue Kick Panel Modified for Speaker, Passenger side $15
 Celica scissor jack and lug nut removal Kit with Genuine  Bag $40
Heater Control Valve Pickup 1979-1983 $15 SOLD
Heater Control Valve  Celica GT 82-85 $15
Heater Control Valve Pickup 1984-1988 $15
 Celica/Supra Heater Control & cables 1982-1985 w/ AC $25
Pickup 4x4 Speedo Cable SWB Single Cab 84-88 $25
 Celica GT 22RE Speedo Cable Auto $25
 Hilux Transfercase/tranny Crossmember with mount $25
Pickup Chrome Stick Shift from a w46/5 spd G $20
Complete Tilt Steering Column w/ steering wheel  Hilux Truck 84-89 w/ Key and Cover $140
 Hilux Door Hinges $15
 Truck Power Brake Booster 4Runner Pickup 84-95 $40
 Hilux MudFlaps 4x4 with  Logo 79-83 $70 sold
 Pickup/4Runner Front MudFlaps 4x4 with  Logo 84-89 $60
 Truck Seat Belt Drivers Side 84-89  4Runner $15
 Truck Middle Seat Belt 84-89  4Runner $15
 Truck Complete 88 EFI Intake Hose As Pictured 22RE $40
 Truck 2.4 Timing Chain Cover 22RE $10
1984  CELICA GT STEERING WHEEL HORN CAP $25
 Truck Rear View Mirror Light Gray 84-88 Truck 89 4Runner $25
 Hilux Gas Tank Great shape Carbed 22R 4x2 84-88 $120
 Truck Hood 84-88 Pickup 89 4Runner OEM #54480 $90 SOLD, 2 dented ones available $20 each
 Truck Complete Headlight Assembly Right 84-88 Truck 89 4Runner with cage worked when pulled $15
 Truck Complete Headlight Assembly Left 84-88 Truck 89 4Runner with cage worked when pulled $15
79-95  Truck Power Steering Pump 105,000 Miles 20r 22r 22RE $30
 Truck Great shape Rear Axle housing 4x2 $125
 Truck Alarm System + Wiring Harness MT 4x2 22R 1987 with Functional Alarm, keyfob + Horn $200
 Pickup 4Runner LH RH axle shaft with drum brakes $40
 2wd Truck Rear 8" Differential + Third Member 4.10:1 79-88 Great Shape $180
84-88  PICKUP REAR LEAF SPRINGS 4WD 1/2 TON $100 sold
 Pickup Heater Box + Core 84-89 94,000 miles $40
1980  Hilux Coil + Distributor 20R Pickup Truck $150 $old
 Truck Tinted Rear Window w/ Gasket 84-95 $50 Sold Mike
 Truck 22R Carb + Intake Assembly 83-89 4Runner $140
Some 84-88 p/u interior, exterior, Some 22r engine parts, feel free to ask for price/items and I'll look
22RE bare engine block, core, $40 spoken for
22re Crankshaft, used, $40 SOLD, 1 might be available
82-85 Celica AC Condenser $40 SOLD
82-85 Celica starter $30
82-85 Celica alternator $50
Celica auto relay $20
Toyota Celica 22REC 82-85 Celica Throttle cable $25
Excellent condition Rear 4.10:1 2wd 5lug axle from my second gen with excellent leaf springs still bolted to the spring plates $300
Rear 4cyl IFS Driveshaft $80 some rust
$400 Celica Engine I might be keeping it
Heater air box with blower motor $30 obo
pair of inner fenderwell panels $30
Coolant overflow 84-88/89 best offer 2 or 3 available
2 chrome lh drivers 84-88 side marker lights $20 ea 1 lh drivers $15 rh was sold 04/27
Plastic cover for your ifs steering shaft $5
Located in New London County 06320 Connecticut. Thanks for your time. Pictures will be uploaded. PM me or respond here if you don't see what you're looking for. 7+ year Paypal Member.  I also accept Amazon Payments
« Last Edit: August 21, 2014, 12:18:48 PM by Erick561 » Logged
jgreen
Offline Offline
« Reply #1 on: May 21, 2014, 05:10:03 PM »
Do you have a front hub off the 82 cellica if so how much shipped
Logged
Erick561
Offline Offline
WWW
« Reply #2 on: May 25, 2014, 09:01:41 AM »
hey, sorry i didn't respond sooner.  I sold the rolling chassis.  I still have 4 toyota wheel covers
Logged
Erick561
Offline Offline
WWW
« Reply #3 on: May 25, 2014, 09:20:52 AM »
I didn't subscribe to my for sale section.
20/22r/e Crankshaft Harmonic Balancer w/ AC pulley sold, 2 available
both clutch pedal assemblies sold, power steering box sold, both pairs of IFS hubs sold
1st gen tow hooks sold, 2 sets of 84-88 hooks still available
84-88 radio brackets sold, 1 pair left.  4wd gas tank bracket still available, reverse - brakelight separator sold
Custom front grill guard winch mount sold thru Paypal $263 after S/H shipping to Colorado. Chrome front bumper 84-88 89 4runner still available, $80
2wd w55 Top shift sold, complete clutch hardline res slave sold, flywheel sold. 1 each available
22RE coolant bypass tube sold, 1 left
Let me know what you need, thanks.
Logged
Erick561
Offline Offline
WWW
« Reply #4 on: June 11, 2014, 03:35:37 PM »
bump, parts have been selling so pm me if you don't see what you need and if I still have it I can help you out
Logged
yfz480corey
Offline Offline
« Reply #5 on: June 12, 2014, 05:29:51 AM »
How much for a harmonic balancer shipped to 35051?
Logged
Erick561
Offline Offline
WWW
« Reply #6 on: June 12, 2014, 08:07:41 AM »
with or without ac?
Logged
Erick561
Offline Offline
WWW
« Reply #7 on: June 12, 2014, 08:08:13 AM »
sorry, the response went to my junkmail folder so i didn't respond til now
Logged
Erick561
Offline Offline
WWW
« Reply #8 on: June 12, 2014, 08:56:48 AM »
pm sent KreepyKrawler
Logged
Erick561
Offline Offline
WWW
« Reply #9 on: June 12, 2014, 09:47:16 AM »
corey, paypal :-)  automatically calculates shipping
Logged
Erick561
Offline Offline
WWW
« Reply #10 on: June 17, 2014, 01:39:21 PM »
bump i just got in another parts truck 1987
Logged
Erick561
Offline Offline
WWW
« Reply #11 on: June 20, 2014, 11:53:52 AM »
Logged
Erick561
Offline Offline
WWW
« Reply #12 on: June 21, 2014, 04:50:18 AM »
 Pm sent   Bean 80. UPS Ground is cheaper.  I can get that shipped out first thing Monday 6/23/14
« Last Edit: June 24, 2014, 04:22:08 AM by Erick561 » Logged
Erick561
Offline Offline
WWW
« Reply #13 on: June 24, 2014, 04:24:04 AM »
Top shift RF1A Stick shift, also have the 79-83 shift boot and knobs
L50 stick shift best offer
1st gen 22R 1982 Hilux Engine mounts 2wd sr5
[youtube]
MVI 3340
[/youtube]
g54 transmission sold, tcase still available
w56c from a 1988 4cyl 22re forward shift
RF1A Forward shift transfercase that was behind my w56-c forward shift
g54 stick shift and rf1a forward shifter
Logged
Erick561
Offline Offline
WWW
« Reply #14 on: June 29, 2014, 08:09:10 PM »
22r carb sold, 1 left
« Last Edit: July 01, 2014, 06:32:17 PM by Erick561 » Logged
Erick561
Offline Offline
WWW
« Reply #15 on: July 04, 2014, 01:35:11 PM »
blue ash tray sold 84-88
tailgate bedliner sold
Logged
Erick561
Offline Offline
WWW
« Reply #16 on: July 04, 2014, 04:54:51 PM »
Logged
Erick561
Offline Offline
WWW
« Reply #17 on: July 04, 2014, 05:29:39 PM »
8422RENoheadCrankRotates.mp4 Videos of me rotating the crankshaft (head off)
8422RECrankwheadrotates.mp4 Rotating the crank with the head back on, bottom end view
8422RECrankRotatesTopEnd.mp4 Rotating the Crank with the head back on, top end view
Logged
Erick561
Offline Offline
WWW
« Reply #18 on: July 07, 2014, 07:36:01 AM »
2wd 1982 Hilux SR5 Cali Emissions 22R engine that only had 64,000 miles on the odo, can't remember if it was auto or manual but heres a recent pic of the carb.
Logged
Erick561
Offline Offline
WWW
« Reply #19 on: July 07, 2014, 07:37:55 AM »
v6 90,000 miles
AC Compressor brackets
Thanks Again Speltwrong on www.pirate4x4.com
"Recieved the G series Transmission on Wed 02 JULY 2014. Packaging was very thorough and the unit was not damaged. I installed the transmission in my 1985 Toyota pickup with existing transfer case and parts. Transmission works well and does not appear to be damaged or burned. No strange noises or grinding. Thank you for a drama free order from acrossed the United States! Happy 4th of July!"
Logged
Erick561
Offline Offline
WWW
« Reply #20 on: July 08, 2014, 08:37:09 AM »
The cable heater assembly will come with the screws and the knobs as pictured along with the cover
The heater core had red toyota coolant in it and it is exceptional condition.  it was owned by a grandfather toyota mechanic
Logged
Erick561
Offline Offline
WWW
« Reply #21 on: July 10, 2014, 10:14:46 AM »
82 2wd toyota hilux 22R 64,000 mile carb sold, 2 intake plenums available
Logged
Erick561
Offline Offline
WWW
« Reply #22 on: July 10, 2014, 10:15:42 AM »
Logged
Erick561
Offline Offline
WWW
« Reply #23 on: July 12, 2014, 06:00:28 AM »
20R alternator bracket as pictured in the middle sold, 2 22R/E brackets available
W59 tranny dust shield starter mount available
Logged
Erick561
Offline Offline
WWW
« Reply #24 on: July 22, 2014, 08:08:46 PM »
84 Celica 22REC Tall Long Block Sold for $400 and I have an 88 22RE Laser Long Block for sale still, $450
84-88 complete parking brake assembly sold
84-88 Rear view mirror interior sold, 1 available
86-95 IFS Locking hubs sold
ask, and i'll either know off the top of my head or i'll have to dig through my parts and check if i've got what you need.  Thanks
PM Sent jnowlin, specify which tranny you need, the 22R had a G series and IDK what type RF1A you have if its the forward g shift rails or whatnot.
Logged
Pages: [1] 2 3 4 5 6 7 8   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.21 | SMF © 2015, Simple Machines Valid XHTML 1.0! Valid CSS!
