Sold/Expired 75-95 Toyota Parts for sale - Garage Spring Cleaning, I ship, Paypal Amazon pmts
79-81 front grill headlight buckets bezels front bumper cab sold
79-83 chrome rear sliding glass window available for sale
Pending sale 1985 cab
Pending sale 1987 cab
First come first serve
1981 1st gen wiring harness for sale
1985 22r 4wd wiring harness for sale
1987 22r 4wd wiring harness for sale
87 22r 2wd wiring harness for sale
22RE sold $400 2 engines left
85 front clip sold with windshield $100 two front clips left
87 gas tank sold
2 84-88 windshields left
84-88 single cab floor for sale
Pending sale rear cab section and solid glass window
RF1A from a 94 w56 forward shift electronic speedo pickup
84 22R Gas Tank
88 v6 efi Gas tank
R150 tranny n tcase
Gas tank skid plate
Front skid plate 79-83 style and 84-85 style
86-88 leaf springs
Etc let me know what you need
79-85 rear leaf springs sold, 1 pair left
RF1A Forward shift sold
86-95 Pickup IFS Rear Axle Tube Sold
79-85 Rear 8" Axle Tube sold, 1 left
84-88 Lower Dash Bezel Below Steering wheel sold
84-88 Windshield Wiper Cowl Panel sold 1 left
4wd 4 Cyl Oil Pickup Tube Sold
22R Carb and Intake Manifold Sold none left ATM
2 22R EGR Valves Sold, 3 left
84-88 Drivers side door hinges sold
3 22RE Alternator Adjusting Brackets sold, 1 left, 3 without 2nd ear left
84-91 5spd Analog Speedo Cable Sold
22R Distributor Sold, 1 left
2 22R Backing Plate Shim Adapters sold, 3 left
22RE EFI Intake Manifold with upstream o2 sold
84-88 Grey Sunroof Headliner Single Cab sold, 1 left
4 Speed 20R Toyota Hilux Chrome Shift Knob Sold
Grey 84-88 DLX Steering Wheel Sold
20R L43 4 Speed Shift Lever Sold
20R Intake Manifold Sold
4wd 4cyl Toyota Pickup Oil Pan Sold
Manual Steering 79-85 Box Sold
89-95 Blower Motor Sold
86-88 Windshield Wiper Reservoir Sold
79-85 Steering Box Mount Sold
79-83 Gas tank sending unit float sold Canada
20R Carburetor and Intake Manifold Combo Sold
Exterior 84-88 Single Cab B Pillar Vent Panel Trims Sold
22R G-W Bellhousing sold
1981 22R Top Shift RF1A 21 spline Toyota Pickup Transfer Case Sold
R150F sold $150
W56B Top shift transmission sold $150
W56b top shift transmission stick shift for sale
R150F transmission stick shift for sale
VF1A 23 Spline Top shift transfer Case for sale
RF1A 21 Spline Top Shift Transfercase for sale
1981 L43 Transmission with Stick Shift Bellhousing and Tailshaft for sale
Hit me up the weekend is just starting
2191538d1458949884-75-95-toyota-part-garage-cleanout-left-over-my-build-20160325_171052.jpg
2191546d1458949884-75-95-toyota-part-garage-cleanout-left-over-my-build-20160325_170136.jpg
2191554d1458949884-75-95-toyota-part-garage-cleanout-left-over-my-build-20160325_183951.jpg
2191562d1458949884-75-95-toyota-part-garage-cleanout-left-over-my-build-20160325_190839.jpg
2191570d1458949884-75-95-toyota-part-garage-cleanout-left-over-my-build-20160325_191914.jpg
Also w56 bellhousing and r150f bellhousing for sale more parts than time help me downsize trying to go wheeling again
94 W56D Forward Shift Transmission Sold
84-88 Grey A Pillar Trim Panels Sold
4 Cylinder Power Steering Pump Y Bracket Sold 2 left
84-88 Manual Pedal Assembly Sold
84-88 Windshield Wiper Cowl Panel Sold
84-88 G54 Shift Boot With Base Plate Sold
Pending sale on 1981 Frame
v6 r150 bellhousing sold
2 22R w56 bellhousings sold, 1 left
G54 forward shift lever sold, forward shift g54 transfer case stick shift still available $25 plus shipping
2 84-95 transfer case cross members sold, 2 left
Toyota 4Runner Pickup Starter Relay 22re 22r 4 cyl. 28300-35010 sold, 2 left
22R fan, fan clutch and fan shroud sold, surplus left
22R Exhaust manifold sold, 1 left
84-95 4 cyl front driveshaft sold
79-83 rear tail light housin sold
Toyota hilux rear window sold
22R flywheel sold, 7 left
Complete power steering setup unbolted from 84 engine sold, 84 126,000 4x4 22R for sale
2nd gen 22RE Distributor Sold
L43 4 speed 4wd hilux transmission sold
22R weber 32/36 with intake manifold available on sale
2202810d1459692775-75-95-toyota-part-garage-cleanout-left-over-my-build-20160403_010821.jpg
2202818d1459692775-75-95-toyota-part-garage-cleanout-left-over-my-build-20160403_015339.jpg
gonna help my friend part this MINT 3rd gen out
2206226d1459898662-75-95-toyota-part-garage-cleanout-left-over-my-build-20160405_173844.jpg
2206234d1459898662-75-95-toyota-part-garage-cleanout-left-over-my-build-20160405_173832.jpg
22R backing plate shim adapter sold 4 left
2 water pump pulleys sold
VSV power steering valve sold
Starter relay sold round plug 86-88 one left
22R early header sold
89-95 center console with clock cig lighter and ashtray sold
1991 rf1a 21 spline top shift transfer case from a w56b, no beating around the bush this is in good shape only 160k on the chassis daily driven
1988 3vz-e 3.0 4wd 132,XXX timing belt went engine parts for sale
2207490d1459988503-75-95-toyota-part-garage-cleanout-left-over-my-build-20160406_170241.jpg
2207498d1459988503-75-95-toyota-part-garage-cleanout-left-over-my-build-20160406_170436.jpg
2207514d1459988503-75-95-toyota-part-garage-cleanout-left-over-my-build-20160406_170452.jpg
2207522d1459988503-75-95-toyota-part-garage-cleanout-left-over-my-build-20160406_164650.jpg
http://W56 top shift transmission stick shift sold
4x4 oil pickup tube sold
79-85 sfa drag link sold
84-95 single cab solid rear glass sold, 84-88 single cab rear cab section sold to my returning vdub jetta customer
2208274d1460050213-75-95-toyota-part-garage-cleanout-left-over-my-build-20160407_114427.jpg
75-95 4 Cylinder Radiator Fan Blade Sold, 4 left
89-02 ash tray sold
89-95 chrome front grill available for sale
2209938d1460130541-75-95-toyota-part-garage-cleanout-left-over-my-build-20160407_161001.jpg
84-88 Accelerator Pedal Sold, 89-95 gas pedals left
4.37:1 Differential Sold
89-95 Forward Shift Boot Sold
Pending Sale 1987 Single Cab
Vf1a and rf1a top shift tcases still available, RF1A Forward Shift from a w56 for sale
22R Weber 32/36 DGEV Downdraft Carb mated to 84 22R intake manifold Sold
got an 88 head with machine shop work in to it, spare, thinking about selling it, no valves installed, comes with cam
thinking of selling a 22R head 1984 126k and parting out 20R short block
Various gray 3rd gen interior parts sold, some left
79-83 Gray driver side dimmer vent panel sold
2 22R fan blades sold
1984 22R Gas Tank Sold
84-88 exterior b pillar louvers sold
84-88 hood cable and hood release lever sold
86-95 cv axle sold
84-88 hood latch sold
88-95 v6 3vz engine backing plate sold
RF1A front driveshaft guard shield sold
Pending sale on 22RE gas tank
2223025d1460955627-75-95-toyota-part-garage-cleanout-left-over-my-build-20160417_184017.jpg
2223033d1460955627-75-95-toyota-part-garage-cleanout-left-over-my-build-20160415_152251.jpg
2223041d1460955627-75-95-toyota-part-garage-cleanout-left-over-my-build-20160415_183104.jpg
88 Gas Tank Sold
22RE AC Compressor Bracket Sold, 2 left
84-88 G series forward stick shift lever sold
22R Manual Bellhousing Sold
84 Sway Bar Sold
88 Sway Bar Sold
22R Distributor Sold 1 left
79-85 Rear Leaf Springs Sold
Gas Tank Skid Plate Sold
22R Starter Relay Sold
Very sad to see it go! But its time to part out one of my brother 800MJ 's project rig...Red 92 xcab pickup .. Everything must go we are funding other builds. Engine is .40" over, MAF is modified for side gap spark plugs. Upper intake manifold plenum thermostat threads were retapped for an aftermarket temp gage so it starts hard, but runs strong. Truck has rock rash. Msg me
2228569d1461240489-75-95-toyota-part-garage-cleanout-left-over-my-build-20160421_074153.jpg
2228577d1461240489-75-95-toyota-part-garage-cleanout-left-over-my-build-20160421_074355.jpg
2228585d1461240489-75-95-toyota-part-garage-cleanout-left-over-my-build-20160421_074334.jpg
2228593d1461240489-75-95-toyota-part-garage-cleanout-left-over-my-build-20160421_074316.jpg
2228601d1461240489-75-95-toyota-part-garage-cleanout-left-over-my-build-20160421_074208.jpg
BigPun said:
Do you have a power steering pump 22re
sorry i sold it yesterday
88 3vz Gas Tank Sold
2 22RE AC Compressor Brackets Sold, 1 left
84 Sway Bar Sold
88 Sway Bar Sold
89-95 xcab rear driveshafts sold
1992 rear axle complete $250 cash local pickup
92 22re gas tank for sale
89-95 rear leaf springs sale in queue
Parting out 1992 3rd gen xcab pickup lmk what you need
1992 sr5 4 cylinder digital speedo odometer cluster for sale
2231754d1461456508-75-95-toyota-part-garage-cleanout-left-over-my-build-20160423_105221.jpg
2231762d1461456508-75-95-toyota-part-garage-cleanout-left-over-my-build-20160423_165527.jpg
2231770d1461456508-75-95-toyota-part-garage-cleanout-left-over-my-build-20160423_165515.jpg
89 speedo sold + 92 gray dash pad sold :)
2231778d1461456508-75-95-toyota-part-garage-cleanout-left-over-my-build-20160423_104817.jpg
i still have the main dash sub assembly for sale
2231786d1461456508-75-95-toyota-part-garage-cleanout-left-over-my-build-20160423_104517.jpg
22R high pressure line, power steering pump, fluid cooling hardline with hose, 2 ps pump brackets and TOYODA reservoir with hose sold, 1 left 1992 22re
1992 power steering box for sale 89-95
22r backing plate sold, 2 left
84-88 cab sold, 1 left
92 power steering setup sold, still have the PS box available
79-85 front leaf springs for sale
Crossover steering for sale
4.37 front diff for sale
Ifs skid plate for sale
Lspv for sale 84-95 3 line + bleeder without the actuating arm
2 22RE heads for sale
2235450d1461768757-75-95-toyota-part-garage-cleanout-left-over-my-build-20160426_162847.jpg
2235458d1461768757-75-95-toyota-part-garage-cleanout-left-over-my-build-20160426_162839.jpg
2235466d1461768757-75-95-toyota-part-garage-cleanout-left-over-my-build-20160426_202142.jpg
2235474d1461768757-75-95-toyota-part-garage-cleanout-left-over-my-build-20160425_231709.jpg
79-83 2-line hilux lspv sold
84-88 doors sold 1 pair left
84-88 sunroof sold
Let me know what you need, i just made some space in my inbox.
2 22R fan blades sold 2 left
84-88 hood latch center support sold 2 left
84-88 center dash radio support sub assembly sold 2 left
84-88 heater control face plate sold
89-95 sun visors sold 1 pair left
84-88 v6 89 4Runner plastic heater control valve sold
1992 front driveshaft sold
Transfercase crossmember shield sold, 2 left
Crossover Steering sold $300
Egr crossover plate on back of head sold 2 left
22RE water pump pulley sold
22RE cast iron exhaust manifold with egr tube sold
Pending sale on 1992 xcab frame
2 4.10:1 7.5" differentials for sale
4.37:1 front 8" differential for sale
2240034d1462107864-75-95-toyota-part-garage-cleanout-left-over-my-build-20160430_131240.jpg
2240042d1462107864-75-95-toyota-part-garage-cleanout-left-over-my-build-20160430_131252.jpg
2240058d1462107864-75-95-toyota-part-garage-cleanout-left-over-my-build-20160428_145004.jpg
2240250d1462120479-75-95-toyota-part-garage-cleanout-left-over-my-build-20160501_123153.jpg
1992 xcab frame sold, cab still available for sale
2240258d1462120479-75-95-toyota-part-garage-cleanout-left-over-my-build-20160501_123345.jpg
2240266d1462120479-75-95-toyota-part-garage-cleanout-left-over-my-build-20160430_174515.jpg
1991 front diff
1992 front diff
Solid front axle parting out. Tube is straight
2241626d1462156744-75-95-toyota-part-garage-cleanout-left-over-my-build-20160501_194354.jpg
92 ifs power steering box
2241634d1462156744-75-95-toyota-part-garage-cleanout-left-over-my-build-20160501_124944.jpg
I just sold 2 steering boxes. I'll let you know when I get another one. I have an 86-88 pickup steering shaft and an 89-95 steering shaft for sale. Which year shaft do you need?
I don't know yet, looking for parts to swap my Samurai to power steering. Any difference in the input spline on the boxes wether 86-88 or 89+?
