Sold/Expired 75-95 Toyota Parts for sale - Garage Spring Cleaning, I ship, Paypal Amazon pmts
Erick561
Online Toyota Truck Dismantlation Vendor in CT
I undercut and Ship from New London County, Connec
I have parts left over from my build and need to downsize. I had to obtain and maintain two vehicles for several years but I took too much on so now I'm liquidating. I like to fix these trucks up and parts are becoming harder to find so I don't want these to go to waste.
$100 pair of Truck IFS 4X4 AISIN Manual Locking Hubs 86-95 4Runner
Truck Pickup Pedal Assembly Clutch Brake & Gas PEDAL 84-88 89 4Runner $30
Truck Heater Core & Box 84-88 89 4Runner $40
Truck Transmission + Transfer Case W56 4WD Forward Shift 5spd 86-88 mechanical speedo $250
Truck g54 Transmission + Transfer Case 4WD Forward Shift 5spd 84-89 $280
Truck Transmission + Transfer Case W56 4WD Forward Shift 5spd 92-95 digital speedo $160 tcase sold
TRUCK 4RUNNER 22R 22RE EXHAUST DOWN PIPE $40
84-88 Pickup 4runner 22R Air Box B/O
OEM 84-88 Small Emblem OEM 75351 89119 Truck 4 Runner $10 each
84-89 4RUNNER TRUCK PASSENGER DOOR HINGES top bottom $15
Celica Windshield Wiper Motor OEM 82-85 $25
TRUCK GAS PEDAL 84-89 $10 3 available
84 Celica Power Steering Reservoir, Hard line and Hose 67941 82-85 $40
84 Celica GT 22RE Gas tank float, complete $70 obo
1979-1983 Truck Hood Latch $15
Hilux Truck SR5 4wd Instrument Cluster Gauge Panel Speedo Tach 79-81 $60 Round plug
truck 2wd Manual Steering Box + Mount *Eliminate Power Steer* 84-95 dragrace $50 reduce drivetrain drag increase HP sold
Mechanical Fuel Pump for 22r 20r Truck 4Runner Celica $20
82 83 84 85 86 CELICA SUPRA HEATER CORE $30
84 85 86 87 88 PICKUP HEATER CORE STD SPEC $30
1984 Pickup pedal assembly $20
Truck 4x4 Front inner wheel well plastic liner panel 84-89 4Runner $20 LH RH
1982-1985 Celica GT chrome "CELICA" and "GT" logos $25 each
82-85 Celica/Supra Radio Stereo Pocket Storage Cubby Trim Dash Kit $15
Truck Front DriveShaft V6 4X4 88-95 90K LOW Miles $40
Truck Hood Hinges Blue or Red 84-89 4Runner $25
84-88 Truck Windshield Wiper Linkage Mechanism $20
Pickup Interior Door Molding Blue Grey 84-89 4Runner $30
Truck Seat Belt Left Passenger Side 84-89 4Runner $15
Truck 22re AC Compressor, Clutch 4Runner Celica Corona No Bracket $35 unknown miles recharge
79-83 Hilux Pickup Truck Rear Drive Shaft 4x4 SWB Short Bed $80 SOLD russ
1979-1981 Black Hilux Pickup Grill 4x4 with Emblem $40 SOLD
? Truck 4.88 8" 4X4 Diff Gears Complete 3rd Member 79-95? $300 SOLD
84-88 Truck Door Jamb Blue or Grey Scuff Plates Carpet 89 4Runner $30
? Truck Windshield Trim Panel Cover Cowl No Rust 84-89 4Runner? $40
Truck Power Brake Booster w/ Master Cylinder 4Runner Pickup 84-95 $50
Truck EMISSION CANISTERS 22R Fed 77740 35260 84-88 i think i sold it obo
Truck Windshield Wiper Motor 4Runner 84-89 $20
$40 Pickup 4Runner Front Drive Shaft 4X4 22R 86-95
$60 Truck Manual IFS 4x4 Steering Box 86-1995 PS Delete Drag PreRunner SOLD russ
AM/FM Radio 1423 Pickup Camry 4Runner Celica Supra $10
89-95 Truck White repainted Tailgate with Blue logo $40
79 80 81 82 83 Hilux Pickup Truck IC Regulator $20
84-89 Truck Speedo Cluster Instrument Panel Pickup 4Runner $25
truck cab side ventilation vents (drivers + passengers) 84-88 $20
? Truck Instrument Cluster Bezel Grey ?84-89 LED alarm light $40
Truck Grey Radio Bezel Trim 84-88 Pickup $30
86-88 PICKUP TORSION BARS 68225 68227 $150 Pair comes with female couplings
1975-95 20r 22r 22re OIL PAN 4RUNNER TRUCK 2WD $40
1979-95 20r 22r 22re OIL PAN 4RUNNER TRUCK 4WD $40
82-85 Celica H/B GT A60 License Plate Garnish $35
?Original Celica GT Black Grille w/ Emblem 82-85? $35
Hilux Pickup Truck 20R AISIN CARBURETOR, Celica Corona $70
PICKUP DISTRIBUTOR 22RE 86-95 $75 SOLD
Truck Lower Dash + Heater control panel and cables combo -ac Blue 84-88 $50
Truck Blue, Grey Dash Trim w/ Dimmer 84-88 $25
Hilux Front Frame clip 4x4 IFS Delete SAS Truck as pictured, save time! $70
Pickup 84-88/89 4Runner Blue Front Clip with half the fenderwells $40
84-88 Truck Tail Light Assembly with 22R tail light harness including wired in trailer hookup and reverse lights $60
$120 Truck Custom Grill Guard Winch Mount with Chrome Front Bumper 4x4 84-89
84-88 Truck Side Marker Light Drivers side 89 4Runner $15
84-88 Truck Side Marker Light Passengers assembly 89 4Runner $15
Celica Complete Driveshafts + Carrier bearing 82-85 2-Piece $120
$10 Truck Right Side Fender Blue 84-88 trim for clearance big tire rockcrawl
$10 Truck Left Side Fender Blue 84-88 trim for clearance big tires rock crawl
$20 Truck 2wd 84-88 Red Drivers side fender small dent
Truck Crossmember Trans TCase 4x4 Pickup 4Runner w/ mount $40
84-89 Truck Ignitor Coil 22R Carbed $70 SOLD
OEM Hilux 4x4 Power Steering to knuckle arm Drag Link $40
OEM Hilux 4x4 Sway bar 1979-1985 $50
79-85 Hilux Steering Knuckle Arms $200 SOLD
79-95 Truck Power Steering Pump 20r 22r 22RE with bracket pulley $40
OEM 79-85 Hilux 4x4 Tie rod with Aftermarket Dual Stabilizers + Dual Stabilizer Mount from NWOR $100
Truck Blue Kick Panel Modified for Speaker, Passenger side $15
Celica scissor jack and lug nut removal Kit with Genuine Bag $40
Heater Control Valve Pickup 1979-1983 $15 SOLD
Heater Control Valve Celica GT 82-85 $15
Heater Control Valve Pickup 1984-1988 $15
Celica/Supra Heater Control & cables 1982-1985 w/ AC $25
Pickup 4x4 Speedo Cable SWB Single Cab 84-88 $25
Celica GT 22RE Speedo Cable Auto $25
Hilux Transfercase/tranny Crossmember with mount $25
Pickup Chrome Stick Shift from a w46/5 spd G $20
Complete Tilt Steering Column w/ steering wheel Hilux Truck 84-89 w/ Key and Cover $140
Hilux Door Hinges $15
Truck Power Brake Booster 4Runner Pickup 84-95 $40
Hilux MudFlaps 4x4 with Logo 79-83 $70 sold
Pickup/4Runner Front MudFlaps 4x4 with Logo 84-89 $60
Truck Seat Belt Drivers Side 84-89 4Runner $15
Truck Middle Seat Belt 84-89 4Runner $15
Truck Complete 88 EFI Intake Hose As Pictured 22RE $40
Truck 2.4 Timing Chain Cover 22RE $10
1984 CELICA GT STEERING WHEEL HORN CAP $25
Truck Rear View Mirror Light Gray 84-88 Truck 89 4Runner $25
Hilux Gas Tank Great shape Carbed 22R 4x2 84-88 $120
Truck Hood 84-88 Pickup 89 4Runner OEM #54480 $90 SOLD, 2 dented ones available $20 each
Truck Complete Headlight Assembly Right 84-88 Truck 89 4Runner with cage worked when pulled $15
Truck Complete Headlight Assembly Left 84-88 Truck 89 4Runner with cage worked when pulled $15
79-95 Truck Power Steering Pump 105,000 Miles 20r 22r 22RE $30
Truck Great shape Rear Axle housing 4x2 $125
Truck Alarm System + Wiring Harness MT 4x2 22R 1987 with Functional Alarm, keyfob + Horn $200
Pickup 4Runner LH RH axle shaft with drum brakes $40
2wd Truck Rear 8" Differential + Third Member 4.10:1 79-88 Great Shape $180
84-88 PICKUP REAR LEAF SPRINGS 4WD 1/2 TON $100 sold
Pickup Heater Box + Core 84-89 94,000 miles $40
1980 Hilux Coil + Distributor 20R Pickup Truck $150 $old
Truck Tinted Rear Window w/ Gasket 84-95 $50 Sold Mike
Truck 22R Carb + Intake Assembly 83-89 4Runner $140
Some 84-88 p/u interior, exterior, Some 22r engine parts, feel free to ask for price/items and I'll look
22RE bare engine block, core, $40 spoken for
22re Crankshaft, used, $40 SOLD, 1 might be available
82-85 Celica AC Condenser $40 SOLD
82-85 Celica starter $30
82-85 Celica alternator $50
Celica auto relay $20
Toyota Celica 22REC 82-85 Celica Throttle cable $25
Excellent condition Rear 4.10:1 2wd 5lug axle from my second gen with excellent leaf springs still bolted to the spring plates $300
Rear 4cyl IFS Driveshaft $80 some rust
$400 Celica Engine I might be keeping it
Heater air box with blower motor $30 obo
pair of inner fenderwell panels $30
Coolant overflow 84-88/89 best offer 2 or 3 available
2 chrome lh drivers 84-88 side marker lights $20 ea 1 lh drivers $15 rh was sold 04/27
Plastic cover for your ifs steering shaft $5
Located in New London County 06320 Connecticut. Thanks for your time. Pictures will be uploaded. PM me or respond here if you don't see what you're looking for. 7+ year Paypal Member. I also accept Amazon Payments
Do you have a front hub off the 82 cellica if so how much shipped
I didn't subscribe to my for sale section.
20/22r/e Crankshaft Harmonic Balancer w/ AC pulley sold, 2 available
both clutch pedal assemblies sold, power steering box sold, both pairs of IFS hubs sold
1st gen tow hooks sold, 2 sets of 84-88 hooks still available
84-88 radio brackets sold, 1 pair left. 4wd gas tank bracket still available, reverse - brakelight separator sold
Custom front grill guard winch mount sold thru Paypal $263 after S/H shipping to Colorado. Chrome front bumper 84-88 89 4runner still available, $80
2wd w55 Top shift sold, complete clutch hardline res slave sold, flywheel sold. 1 each available
22RE coolant bypass tube sold, 1 left
Let me know what you need, thanks.
Top shift RF1A Stick shift, also have the 79-83 shift boot and knobs
L50 stick shift best offer
1st gen 22R 1982 Hilux Engine mounts 2wd sr5
[youtube]MVI 3340[/youtube]
g54 transmission sold, tcase still available
w56c from a 1988 4cyl 22re forward shift
RF1A Forward shift transfercase that was behind my w56-c forward shift
http://www.pirate4x4.com/forum/attachments/engines-trannys-t-cases-sale/1316442d1399931814-2
[img]http://i219.photobucket.com/albums/cc64/NetraToy/For%20Sale/IMG_3346.jpg
g54 stick shift and rf1a forward shifter
v6 90,000 miles
index.php
AC Compressor brackets
Thanks Again Speltwrong on www.pirate4x4.com
"Recieved the G series Transmission on Wed 02 JULY 2014. Packaging was very thorough and the unit was not damaged. I installed the transmission in my 1985 Toyota pickup with existing transfer case and parts. Transmission works well and does not appear to be damaged or burned. No strange noises or grinding. Thank you for a drama free order from acrossed the United States! Happy 4th of July!"
