Sold/Expired FS: SAS'd 3rd Gen 4runner Fayetteville, AR
LDT98
Member
I built this 4runner with the help of a few knowledgeable friends. The quality of fab work and layout of the 4runner is shown fairly well in my build. This is my daily driver and it runs and drives great at all speeds. This 4runner will wheel some of the harder trails around and give you the comfort and smooth ride you want around town or down the highway.
2001 4runner SR5 (with leather) 131,xxx miles, 3.4L V6, Auto trans, 23" frame hight on 37's
Front Suspension:
12" ORI's
Custom Radius arm setup using 2" DOM .250" wall tubing and 3.0 Ballistic joints
Ballistic fab heavy duty frame link mounts
Front frame reinforcement plates
Modified All Pro upper coilover towers
Ballistic fab Dana 44 coilover mount/gusset for lower mount
Rear Suspension:
FJ80 coils
OME shocks
Rear shock mounts relocated for more ground clearance
Extended rear sway bar links
Front Axle:
High Pinion Dana 44
Cromo inner and outer shafts
Yukon super joints
Warn premium lockout hubs
5.38 Reverse cut gears
ARB air locker
Flat top knuckles with high steer arms
GM 1 ton steering with moog joints
SOLID diff cover
This axle was built hub to hub with all new seals and bearings as of 10-14-13
Rear axle:
Stock toyota axle housing
ARB Air locker
5.29 Gears
Wheels and Tires:
37x12.50r17 BFG KM2 90-95% tread
17x9.5 4" BS Raceline Beadlocks
Drive Train:
Stock except for B&M tranny cooler and custom front square tube driveshaft
Armor/Recovery:
Modified Addicted offroad front bumper 1.5-2" more tucked in
Addicted offroad rear tube bumper
Custom radiator skid
Custom belly skid
63" Custom square tube sliders
1st gen roll bar in back for storage and mounting
Smittybilt X20 10K with synthetic line & aluminum hawse fairlead
Rear control arm mount skids
Lighting:
16 CREE LED rock lights
4 CREE LED interior lights
20" single row CREE LED bar off brand
2 square CREE LED pods off brand
Performance:
Deck plate mod
Internal snorkel
Water pump, timing belt, and all over belts changed at 111K
Electronics:
Scan gauge II Hardwired
Dikota digital SGI-5 (to make speedo spot on)
Marine Die Hard Platinum battery
Pioneer P3400BH head unit with backup camera/night vision, Bluetooth connect, hands free calling, DVD and more
Sony amp
JL audio sub mounted in storage area on back passenger side to save cargo space
Steering:
86-88 Tapped IFS toyota box
Power steering conversion kit
Drop pitman arm from TG
PSC 6" hydro assist ram
Modified toyota pump to run slightly higher pressure
Steering shaft with borgeson joints
Firewall kit
Other:
Quick release pins for quickly taking doors off
Ruff stuff track bar kit
T-100 Oil pan
Diff breathers
ARB Air compressor with tire fill kit
Modified crossmember
Black weathertech digital floor liners
Front blinkers relocated to parking lights
$17,999 Will consider full or partial trades but would rather sell outright. Mileage will change slightly as I drive this everyday. Needs nothing ready to go. Everything works perfect and I wouldn't hesitate to hop in it and drive it anywhere country. If you have any questions or want spacific pics or video it's best to call or text me as I don't check the forums daily 479-422-6862
Some but not all of my build can be seen here http://www.toyota-4runner.org/3rd-gen-t4rs/128788-adh8796-4runner-build.html
I've had a deal in place with someone and was waiting for it to play out. Anyway long story short the trade I was going to take is a bit too rusty for me so I'm passing on the deal.
New price $17,999 I've got a lead on a couple things I want so I'm pricing low with hopes to make a quick sale. I'll still consider trades but would rather just make a cash deal.
