TRD
- Joined
- Sep 3, 2015
- Messages
- 189
Get the highest performance at the lowest cost with AccuTune!
We deliver the best performance because we have spent 15 years tuning and engineering shocks and we know what works and what doesn't. Our valving is 100% pre-tuned for your ride so you don't have to spend a bunch of time and money fixing generic tunes. Each tune is based on engineering and hard numbers so there's no guessing about what's right for you. To learn more about us check out our home page at AccuTuneOffRoad.com.
In addition to amazing performance, we're also some of the least expensive.
We save you TONS of money because we try to get it right the first time, and because our fine tuning services are inexpensive or free.
Spring Swapping:
Competitors charge for swapping ($10 to $20 per spring)
Competitors don't have springs in stock - long lead time
Competitors have limited time frame for returns (90 days max)
Competitors make little to no effort to get your rates right
We significantly reduce the number of spring swaps by trying our best to get the rates correct up front.
If you do have to swap springs we don't charge for swapping, offer unlimited spring swaps, have springs in stock, and don't have a time limit.
Our terms & conditions: Springs need to be like new, and customer pays shipping on swaps.
See the fine print here: http://accutuneoffroad.com/terms-conditions/
Valving:
Competitors sell stock valving that is harsh and bucks
Valve disks are $35+ per shock min
Tuning sessions are $350-$500, plus cost of getting there
Because our valving good most people never need to re-valve, and if you do it's usually a minor tweak.
When you add it up, we can easily save you $100 to $200 per shock, and your rig will work better right out of the box!
Here are some links to shop and learn about our most popular products:
Fox Shocks
Fox Air Bumps
Fox Air Shocks
Fox Bypass Shocks
Fox Coilover Shocks
Fox Smoothie Shocks
King Shocks
King Air Bumps
King Air Shocks
King Bypass Shocks
King Coilover Shocks
King Smoothie Shocks
To learn more about custom tuning & simple methods for measuring your vehicle follow this link to our article about http://accutuneoffroad.com/articles/how-to-perform-accutune-measurements/.
Note that we can tune shocks even if you only have estimates on your numbers.
[size=10pt]As always:
Custom Tuning
Free Shipping
Spring Swapping
Valve Disk Swapping
I've got a special discount for the first person who can tell me what this means:
-Ryan
909-265-4443
Spring Swapping:
Valving:
Fox Shocks
Fox Air Bumps
Fox Air Shocks
Fox Bypass Shocks
Fox Coilover Shocks
Fox Smoothie Shocks
King Shocks
King Air Bumps
King Air Shocks
King Bypass Shocks
Custom Tuning
Free Shipping
Spring Swapping
Valve Disk Swapping
-Ryan
909-265-4443
