Sold/Expired Stretched CJ7- Just keeping it
Gadametz
Little Rock AR
About the only parts that are still jeep are the hood, body, and frame.
83 CJ7 tub and body
stretched to 126" wheelbase
clean title
Front Axle
Front is a 84 ford 60 from a dually
has a locker and geared to 4.56
locking hubs
high steer
full hydro steering
yukon shafts and joints
disc brakes
Rear Axle
sterling 10.25 welded
4.56 gears
new disc brakes
Suspension
front and back are on coils and rancho shocks
lower links are made from a trailer v
bulletproof and rock solid
Wheels and Tires
44x18.50x16.5 tsl's in the front
44x19.50x16.5 boggers on the rear
tires have rock rash and a few plugs but all hold air for weeks at a time
wheels are H1 double beadlocks
Drivetrain
fuel injected 90's Ford 460 that runs great
C6 trans
203/205 doubler tripple stick
B and M slap shift shifter
10k winch needs remote
headlights work
corvette radiator
2 new batteries
35 gallon fuel cell
double trans coolers and extra oil cooler
5019188288
10,500 obo
Little Rock, Ar
Can deliver to SuperLift in Hot Springs
Re: 79 "CJ7"
so it has a trailer v neck for the links? what does it have at the frame side for a joint?
Re: 79 "CJ7"
I'm sure he used the "big"'ball and receiver. 2 5/16 ball is the only way to go when one linking. You don't want to chance it and use the small 2inch ball.
Re: Big Block Powered CJ7
Gadametz said:
Yes the hitch ball is where it connects to the frame. It flexes surprisingly well and is very strong
Surely its not really?
Not trying to start anything and it doesn't make much difference but, im pretty sure thats a mid 80's 60 front and not a 79. Nowhere near the room on the driver's side axle tube to be a 78-79.
Old hillbilly one link: serves as rear drive shaft skid too seen first one at tellico about 17 years ago when everybody was converting from leaf springs to coils strong as hell good luck with sell looks like a stuff jeep
Are those h1 s recentered? Are they original back spacing?
You could be right. I'm just going off of what I was told by the previous owner. I've been trying to go over it but I couldn't tell you the difference
That's crazy. I've never seen one setup like that before. GLWS
