Sold/Expired Toyota 4Runner Buggy, 4 seater, blown motor SOLD
TBItoy
Dodson Branch, TN
87 4Runner that I bought bone stock in 06 and built up since then.
Sold it to my buddy Gabe a few years ago, he tubed the front end last year.
Damage was done at the HL ride at GMP
BAD
Engine is blown, huge holes in both sides of the block, but it still drove out of the woods and onto/off the trailer.
GOOD
Built to hell front axle, 4.10
High Pinion diff with v6 carrier/locker
OG 30 spline Longs (RCVs)
Huge top and bottom knuckle steering arms tied together
ALL ARP studs
TG trunnion bearing eliminators
TG drive flanges
TG 8" DE ram
TG 1650 PS pump
Rear axle
V6 with Aussie 4.10
1/4 wall drive shafts
TCASES
Marlin Crawler R10 double case (10 degree rotated) flat belly
Long (RCV) rear output shaft
23 spline 4.7 rear case
Corbeau ultra front seats
Corbeau bench
4 harnesses
All cage is DOM, front clip is hrew
3 link panhard front
4 link rear
Jeep ZJ coils front
TJ front coils rear
Generic white shocks
38.5 Aetna cut SX
One has a big hole in the sidewall where it was previously vulcanized
15x8 2" backspaced W/ rim stiffeners
INNER AIRLOCKS
It's really a "firewall buggy",
No stock floor, seats are mounted like a "real buggy" on tube framework with tabs, loop over driveshaft, etc
No stock front sheet metal, radiator/lights/etc are all on tubework
WINCH
Tmax 9500 with synthetic rope
Cooler rack between rear seat and gas tank, large ammo can tool boxes(also keeps the kiddos legs in)
Drop a motor in and fix the tire and you are ready to ride.
$3000
Call/text Gabe 931-239-7903
Grimsley, TN
Re: Toyota 4Runner Buggy, 4 seater, blown motor
is that a fj80 front with home made high steer? Any issues other than the motor. I love golden mountain. It is hard on parts. Nick are you selling or posting for your friend? EFI motor ?? I see the tank. nice budget ride.
Mini truck front with HP diff. custom steering arms with ATP studs top and bottom.
Yes EFI,
Ready to ride (as far as I know) except the motor and the bad tire.
I'm just listing it for Gabe, it's at his house.
I've really considered buying it back, but I don't need 2 Toyota rigs.
I believe I still have the title to this also (it is/was in my name) if anyone is interested.
This rig will go, watched Gabe crawl the top of bounty hill at GMP
That's an awesome ride at a great price :spin:
Great guy and awesome transaction. Thanks Gabe.
Sent from my SM-G900V using Tapatalk
Thanks
Gonna get it going and test it out. Probably gonna add some sheet metal, radio, and go from there.
Got it running and driving again. I also looked at the build thread. It's came a long way. I sanded and painted it, added gauges, engine swap, new alternator, now has trail ready beadlocks and 37" xterrains.
Nice.
It drove pretty decent on the road before, with the 37 Xterrains it should be pretty good. Just need some tail lights. Should be able to get a tail light pigtail and plug it in at the kick panel.
Ok. I'll definitely Give it a try. Also. I saw in the build page that you had seat sliders on it before. If I bought those sliders from chassis unlimited would they work without altering anything?
Yeah they should bolt in, you have to put a thick washer between the tab and slider on one side because of how the the seat/chassis tab line up.
Kinda hard to explain, but it becomes obvious when you have them in hand.
Took it to Dixie run. Did great.
