Sold/Expired LAST PRICE DROP - Mostly tube Zuki, "Light is Rite" -
GeezerX2
Member
1987 Suzuki Samauri
I need this rig out of my garage. OFFERING it for $3,200 AND I have some more spare parts I will throw in!
Last chance this fall, before I pull it out and put it into storage for the winter!
1.6 - 8v engine from a 1993 Tracker, less than 100k
Weber two barrel carb
Header
Sami 5 speed
4.1 gears in t-case
4.88 gears with spools in both axles
34 X 10.50 – 15 LTB's, DIY bead locks on 8 inch wheels
Wheel base is 85.5 inches
Weight is 2,320# with winch and tools LIGHT IS RIGHT !
Disc brakes all around
Spring over axle lift
Fiberglass seats
Tool / spare parts box in the rear with a place for your cooler too!
Front axles, heavy duty chromoly
Over the top steering with power steering
Front axle housing is trussed
Rear axle house is Hybrid heavy duty from Sky Manufacturing using Chevy Tracker 8 inch gears
Rear drive shaft is Toyota
Winch, (Warn 8,000#), and battery both mounted low in the rear for better weight distribution
Hi-Lift jack mounted on cage
Spare drive shafts
PRICE DROP TO $3,800
Built and improved by the same owner over the past 13 years
Plain and simple rig that has impressed many and been a hoot to drive
Located in northern Michigan, Interlochen to be exact
Feel free to text 810-869-0025 or email Gary at: [email protected]
PRICE DROP
Offering with a reduced price and a few more parts.
I need my garage back, so come grab it now before I put it into storage for the winter!
$3,200...................
