buggy is a 2014 jimmy smith finished in April of 2015 it is set up on 120in axle to axle I'm 6.1 200lb and have room for a helmet and my fist above my head buggy is powder coated sky white and matte black buggy has never been upside down few small scratches on door bars from getting in and out nothing deep or bad located corbin KY 40701 removed buggy from hardline a while back had buyer put down a deposit and wasn't able to tie up something on his end so putting it back up asking 35,000 obo
extra lq4 is in machine shop getting bored .30 over with 317 heads milled 20 thousands everything in 5.3 will work in 6.0 motor cam, springs and push rods
powertrain
5.3ls with fresh rebuild Texas speed 228r camshaft with double springs and harden push rods running a ls1 intake with ls1 fuel system computer was done by Jim's performance has a th350 with a np205 has 1350 yokes front and rear
axles
Dana 60 in front with Yukon shafts super joints sky manufacturing arms tied into stock location with harden studs had Reid racing brass bushings 4.56 gears Yukon with spool rpm drive flanges 35 spline
14 bolt rear with 4.56 Yukon welded carrier stock shafts yokes are changed to 1350 u bolt style not straps
suspension is radflo 2.5 16in with 200lb springs on bottom all four corners and 150 up front and 100 rear links are 1 1/4 chrommoly with 2in 250 wall they are left and right thread has wide open design limit straps I'm sure I'm forgetting stuff just ask if you have any ?
powertrain
axles
