They're here!!
17 by 10 inches of made in America greatness.
We machine this wheel in house on our Haas CNC mill to make them accurate. We stamp each piece for accuracy so you know how to assemble them.
Your choice of rock ring. Your choice of powder coat colors.
Short video showing some of the in house machine process.
Trail Worthy Fab Double D bead locks in the making.
Short video showing you there is no hop in our wheels because of our manufacturing process.
Trail Worthy Fab Double D beadlock
This double bead lock uses an internal insert made specifically for this wheel. We also cut them for your exact tire so the tire will never spin on the wheel and you'll never lose a bead. The PVC insert centers itself on the wheel so you can't install them wrong. When they center on the wheel it helps with balancing your combo.
Stupid simple gaskets made specifically for our 17" Double D bead locks!
DETAILS:
- 100% Trail Worthy Fab wheel. This isn't a different wheel modified to be a double. It was designed to be a double from the beginning.
- 100% made in the USA!
- 17x10 with many different back spacing options.
- 100% guarantee on our craftsmanship.
- CNC spun to match the design I wanted so it has the same strength TWF is known for. We CNC spin the hoops for accuracy. This helps you balance your wheel and tire combo.
- Same type of H1 rock rings can be done and welded in place. We modify the pattern to match up to the 17.
- PVC inserts to hold the bead in place custom cut to the tire you are running so it is done correctly.
- Same pressed centers as the H1 so we know what we are starting with.
- Every bolt pattern.
There are many finer details about this wheel that are very nice. Check them out on our site here:
17" Trail Worthy Fab Double D Bead Locks
DETAILS:
