Sold/Expired Turn key buggy Built by "Tuckers Off Road"
rparker
Member
"Buck Nasty" $26000
Turn key buggy completed in 2012 "Tucker Off Road"
• 188 tube on all lower frame rails and suspension mounts
• 120 wall on the rest of the chassis all DOM
Suspension
• Front - double triangulated 4 link with 7/8" Ruff Stuff heims with .250 DOM links
• Profender 16" Coil Overs with 2.0 Fox air bumps
• Rear - double triangulated 4 link with 7/8" RuffStuff heims with .250 DOM links
• 18" Fox 2.5" air shocks
Engine:
• Fresh GM 383 stroker with GM bowtie heads and Comp. Xtreme 4x4 cam ( less then 4 rides on motor )
• Propane injection
• 180 headers
• Edelbrock Performer Intake
Transmission - newly rebuilt Turbo 350 with Heavy Duty clutches ( 2 rides )
• Derale cooler with fan
• Winters shifter
• Transfer case- NP205 twin sticked
• heavy front output
• 1350 front flange , 1410 rear yoke
Axles :
• Front - new style GM 14 bolt with gusseted and plated 60 king pin knuckles
• Blue Torch fab high steer arm w/ anti sheer brace
• Ruff Stuff pinion and Diff guard
• 5:13 gear with full spool
• RCV 300M 30 spline inner with 35 spline out shafts
• ECGS Drive flanges with Tuckers Offroad covers
• disk brake
• 1350 yoke
• Rear - old style GM 14bolt
• Ruff Stuff diff cover and pinion guard
• 5:13 gear/ welded
• disk brake
• 1410 yoke
Steering
• Trail Gear Orbital
• Tractor Supply 2x8 Ram
• Stock GM pump modified
• ALMN. finned cooler
Tires/Wheels
• 44" Super Swamper TSL 50-60% tread front Aetna Cut rear Tennessee cut
• Steel wagon wheels with Tuckers Offroad Almn. rock rings
Random
• 1410 EOR rear drive shaft ( new )
• 1350 front drive shaft with carrier bearing
• 20" Redkneck Light bar
• Kirkey Seats ( extra wide 19" )
• 3 propane tanks
• Buggy has never been rolled...yet. It will be wheeled until it sells
• No major damage to chassis anywhere
• Motor, trans, front axle and drive shafts are new within 10 months
• Auto Meter gauges
• HEI distributor with MSD internal Rev limiter
• Built for 6 foot plus sized people
* Buggy needs nothing and is ready to ride, very strong motor and proven setup *
Rob Parker
[email protected]
607-742-6679
Watkins Glen NY
I can help with any questions if needed , i built this unit and have maintained it most of its life . Buggy works great it'll craw and bounce . It's one of the healthiest propane engines I've been around it has no issue burning the 44s down! Great buggy someone will be very happy .
I could also possibly help with delivery to the south if it's to go that way . I always can use a good excuse to come down and hit a park or two and bring one of mine ! booyang
I May be interested in trading for. Corvette convertible, razor 1000, speed boat or 2012 newer JKU.
Price Drop to $26000
Also interested in go fast boats
Street glides
Hot rods
Corvette Convertible[flash=200,200]http://[flash=200,200][/flash][/flash]
TTT for a good buggy with very little use on 80% of the components that are new or rebuilt ! For anpekpane buggy this thing gets it! It's the snappiest pane motor I've ever been around :woot: we are talking of redoing the back end to carry two propane tanks in the upright position
