Bought practically new besides a few shake down runs summer 2015. Has been my wife's buggy - been out approximately 10 times. Original owner had WOD build it to a roller then finished it at his shop. Have all receipts from original build.
Here's a link to the build thread: http://www.hardlinecrawlers.com/forums/index.php?topic=20170.0
WOD Chassis - lower bars and subframe are 1 3/4 x .188 wall DOM, rockers and sliders are .250 DOM, and the rest is .120. All skids are UHMW. Wheelbase is 113.
Engine is an aluminum L33 5.3 HO rebuilt by Jeff Burns Performance Engine Works. Cammotion XA 212-330-218-330-112+4, Comp Cams 5/16 7.40 Hi-Tech pushrods, 799 Heads redone with Z06 valves/5.70 valve springs, LS2 timing chain, ported oil pump, LS6 intake, injectors, TB, and MAF. All Delco sensors, Mast Motorsports oil pan. Harness and ECM are from an 02 Firehawk tuned by Wayne Hartwig at 150tunes. LS1 starter and water pump. WOD's complete GM LS engine alternator and PS pump relocation kit. Sanderson Headers 2 1/2" to 3" WOD exhaust kit, all V-band, Magnaflow race muffler
TH400 with reverse manual valve body, Alto Red Clutches, Art Car Shifter, and two Griffin coolers with fans
Atlas 4 speed - lowest gear 5.44:1 - bought new and professionally installed since I've had it
78' - 79' Ford Snowfighter High Pinion 60 front axle with Yukon 35 spline Chromoly Shafts, Superjoints, ECGS Spool, 4.88 gears, forged 1350 yoke, Crane Knuckles, interlocking Crane High Steer Arms, Crane Drive Flanges, PSC 2.5 x 8 steering ram, WOD truss, ram mount plate, and tube work
14 Bolt rear, shaved with UCF 13 bolt cover, Spool, thick cut 4.88 gears, forged 1410 yoke, Ruff Stuff Caliper brackets, Pinion Guard, Lugnut 4x4 brake kit, WOD Truss
Links are polished 7075 Aluminum 2 1/4 lowers and 2" uppers
14" ORI STX struts with remote reservoir - bought new and professionally installed last year
Griffin 31-16 Dual pass radiator with two SPAL fans. 16 AN Fragola fittings throughout cooling system
WOD Brake plumbing kit, all AN, Dual Wilwood Master Cylinders, residual valves, brake light switch, reverse flood light, Ruff Stuff Aluminum rear Ultra 4 light setup, LED interior strip
WOD GM Non-return style fuel plumbing kit with Walbro pump and pre-filter safety shut off valve - all AN. Had a new 22 gallon JAZ Fuel Cell with an Artec bracket installed since I've had it
43" Super Swamper TSL SX Sticky tires on 17" Raceline Beadlock Aluminum wheels - approximately 80%+ tread life remaining. Also comes with a brand new 43" SX Sticky on Raceline Beadlock spare
Corbeau Baja SS seats and harnesses. Comes with an extra drivers seat - same look but made for taller driver
MISCELLANEOUS: 12 Volt Guy custom switch panel, Fuzion 205ra Marine radio with AUX, USB, and XM/Sirius Radio, Crawltunes speaker enclosures with Infiniti speakers, WOD master power switch, Marine volt meter/charger, 2 fire extinguishers with quick release brackets, Lazer Star headlights and lots of LED rock lights
$40K
Located in Richmond, VA
Will be happy to answer any questions or provide additional pictures/information 804-754-6778
Pics were taken yesterday and buggy will not be driven until sold
$40K
