fabricator1
- Joined
- Sep 16, 2012
- Messages
- 493
Shocks are gone. They got snatched up right away. But stop by anytime. There always some projects going onSHARPMACHINE said:I would like to check out the shocks. I have also talked to Fabricator a couple times to go see other stuff he may want to sell. Let me know when a good time is.
Thanks
Pm your # again. I think the kid erased the messages since I talked to you and I don't think I have your number anymoremcrob0202 said:if heed call someone back ited all be gone and ill go there not make him deliver
I haven't ran into that on any front axles. Usually they are a greasy mess. But that being said, I have seen a few bad 14 bolts. It's always the ones that have the u bolts pointing down and that saddle around the bottom of the axle tube. Seems to hold crap and the tubes rust in those 2 spots. I usually cut the tubes off those and save the center for front axle builds. The 14 bolts with the u bolts that point up aren't a problemTBItoy said:Not saying fabricators stuff is like this, but I've bought axles from up north that would have to be retubed to be usable because of rust, brake brackets rusted off. Etc.
Ymmv
fabricator1 said:I haven't ran into that on any front axles. Usually they are a greasy mess. But that being said, I have seen a few bad 14 bolts. It's always the ones that have the u bolts pointing down and that saddle around the bottom of the axle tube. Seems to hold crap and the tubes rust in those 2 spots. I usually cut the tubes off those and save the center for front axle builds. The 14 bolts with the u bolts that point up aren't a problem
fabricator1 said:Shocks are gone. They got snatched up right away. But stop by anytime. There always some projects going on
