Are these any good
Goatrider
The outdoors is my life!!!
North central Ohio
Just weaker versions of 2.5 tons
Sent from my SM-S903VL using Tapatalk
Re: Re: Are these any good
Goatrider said:
So I shouldn't even ways my time I'm assuming even for that low prive
I wouldn't.
Theyre all the weight of Rockwells with the strength probably equivalent of stock tons (or less)
TBItoy said:
I think it's like a 12" ring gear. Real stubby coarse pinion though.
Old technology all around.
interesting
pplblazerdude said:
Saw a set of those blow all to hell last time I was at harlan. Not impressed at all
what failed on them?
The gm also ran reverse rotation front axle because of its wierd tcase.
You would either need the tcase too, get 2 fronts or 2 rears, or flip one.
A local guy ran 2 steering axles in a rear engine rig. He busted a few shafts before going to Rockwells. He had a pile of them to get parts though.
I've drove a few hours before because I was told they were 2.5 ton rocks but get wiithen sight of the trucks and I was like damn those are the junky gm 6x6 no thanks. The only thing I have ever seen on them that was even close to cool but I still passed on was on the first rear end there is a greasable carrier bearing that I've thought about using for a midship bearing
smbroady82 said:
interesting
Not totally sure think a shaft. Barely got onto it and bang crack pop. Then he took a flange off and still popping and cracking. Acted like a shaft
that's crazy, I bet they weigh a ton too
