Sold/Expired 92 YJ, tons, 44's, built SBC 400
gubni
www.lugnut4x4.com
Jonesborough, TN
I traded for this jeep. I thought it might be cool to have it as a trail rig, but I haven't taken it out once. I need to sell it. I will consider trades, but really looking for cash. Asking $11,000. Reply, PM, text, or call 423-737-0265
Below are the specs. I have tried to be very detailed. Most people will say their rig has no problems, but I'm a perfectionist and I know every rig has some problems so I listed that too. The good thing is there are no leaks that I know of.
92 Jeep Wrangler
Clean title in my name
Racing seats
4 point harness
Working heater
Full hydro steering
Aluminum roof
Full cage tied to factory cage
Custom aluminum dash
Back seat (not installed, but should fit)
Dana 61 dodge kingpin front (same as Dana 60 except different ring and pinion)
Spool 5.13 gears
Yukon chromoly shafts
35 spline stubs
Drive flanges
14 bolt full float rear
Disc brake kit with 1980 Chevy k20 jb6 calipers
Spool 5.13 gears
400 Small block chevy motor
Bored to 406
13:1 compression
Aluminum patriot freedom heads
Propane with dual tanks
Electric fan
44" TSL on beadlocks great tread
Leaf spring front
4 link rear
King air shocks front and rear
Turbo 400 transmission with B&M shifter
NP208 transfer case
12,000lb Badland winch
Needs
Steering centered (turns more to the right than to the left)
Better PS pump (works, but whines a little more than it should)
Second fan (doesn't overheat, but I always put two fans on my rigs)
Less brake pedal travel (Brakes seem to work fine, but pedal moves more than I like)
Upgrade to full circle ujoint clips in front axle (makes front axle stronger and they are included)
Blue overspray on the lights needs to be cleaned up
Link to video --> https://youtu.be/dPGoCAJQIc0
