14 bolt shaft lengths, SRW truck
redneckengineered
Trailer Park Panty Dropper
The Land of High Horsepower and Low IQ
Looking for the shaft lengths on ribbed housing 2nd gen 14 bolts (~88-2000ish), specifically from a SRW truck. No dully's, vans, or C&C they have been known to have funky widths...
I'm curious if the 2nd gen SRW truck 14 bolts are the same as the first gen which are 31 5/8 and 37 5/8 give or take an 1/8th.
Thanks
Not sure if these measurements came from "big block" style ribbed housings but according to 2 different ebay f/s ads I just looked at one guy has a 14b ff from a 95 2500 p/u showing a measurement of 32.25". Another guy has a long side from a 99 k2500 with measurements listed as 36.5". So, as far as these axles go, I'd say a gen 1 short side would probably work in a 2nd gen axle. Not sure about a gen 1 long side. It would need to have at least 1.125" of additional spline length engagement available.
Were they for sure SRW trucks because that is strange.
That's what they're saying.
"good used axle just pulled from a 99 K2500."
"if you were to measure it like you would a bolt (usable length) its 36 1/2 "
http://www.ebay.com/itm/AXLE-SHAFT-GM-14-BOLT-10-5-REAR-FULL-FLOATING-STYLE-SIDE-LONGER-SIDE-/332118335091?hash=item4d53cb9e73:g:qS4AAOSw4DJYmm~t&vxp=mtr
"rear axle shaft from a 1995 chevy 2500 with a 14 bolt full floating rear axle single rear wheel. this is the short side driver. axle shaft is 32 1/4 inchs long and 30 spline."
http://www.ebay.com/itm/GM-14-BOLT-FULL-FLOATING-REAR-AXLE-SHAFT-1992-thru-1999-driver-side-1995-2500/253085226231?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D45726%26meid%3D3ee036a8bac24971bd7f90f1d6ecb4e5%26pid%3D100005%26rk%3D5%26rkt%3D6%26sd%3D332118335091&_trksid=p2047675.c100005.m1851
