Not your toy 85
Contact: 770- 687- 7946
Asking price: 16,500 obo
it is an 04.5 which has the 325hp cummins( not the 305hp)the body isn't perfect, it does have dents and dings as it is a truck after all.
the truck has had a lot of money poured into it in the last year. below is a list of whats been done
engine: 24v 5.9 cummins 287,xxx
- o.e. bosch ss body injectors
- cross over tubes done when injectors were installed
- new aluminum radiator and hoses along with coolant flush at the time of replacement.
- new stock exh. manifold with casting marks ground( to prevent cracking)as well as drilled and tapped for egt guage. ( at the same time turbo was cleaned and inspected)
- new cp3 from copperhead diesel
- air dog 100 lift pump 2 micron filtration ( stock fuel filter bypassed)
- diamond eye 4" stainless steel exhaust ( turbo back, and will also include muffler delete)
- k&n intake
- 2 brand new batteries with new terminals and cables
- brand new alternator
Transmission/ t case 48re with np 271
-billet input
-billet servos
-billet accumulator
- kolene steels
- Raybestos clutches
- kevlar 2nd gear band
- gm billet solenoid
- bd metal transducer
- billet filter spacer
- derale +5 qt deep pan
- ats "towing"valvebody
- pts level10 pump
-dpc triple disc billet converter
- has true cool 14x14x2 stacked plate cooler to replace factory one along with derale auxiliary cooler with 1000 cfm fan on 180* thermostat/switch
- max tow trans temp guage installed in fold out ash tray
- all lines are -8 an braided stainless hose.
transfer case was gone through when trans was installed
Wheels/Tires:
- 4th gen 6 spoke 17" polished wheels
- 305/70/17 cooper at3 all terrains only have 5k on em
suspension/ Steering:
- 2.5" leveling kit
- new xrf ball joints ( MILLION MILE WARRANTY)
- new xrf tie rod ends
- new xrf drag link and tie rod
- dual steering stablizers
misc:
- brand new smoked headlights, and fog lights
- brand new led bulbs in both headlights and fog lights
- led smoked 3rd break light
- new brake controller
- weather tech front mats
interior is not perfect but looks good for its age.
It has light white haze on start up after it sits for a while
When rear end was replaced ,it was with an open carrier
Po spilt some sort of glue in the back seat, I have yet to get it out but not for lack of trying :****:
I don't need two trucks.( main reason for selling)
I'm sure there are more details I'm forgetting. feel free to call or text me with any questions. Have most if not all receipts. Some were done by previous owner( injectors /tubes.
(All "new parts"were installed in the last year)
Come take a look and drive before you ask if I'll take some offer sent in a text message while you're 100+ miles away.
- k&n intake
-billet input
-billet servos
-billet accumulator
- kolene steels
- pts level10 pump
Wheels/Tires:
- 2.5" leveling kit
misc:
