Sold/Expired 2000 TJ LS LowMax ORI's
Hotrodfry
Member
Terre Haute, IN
2000 TJ with title, Chevy CUCV axles-4.56 w/Detroit rear 14 bolt w/disc brakes - limited slip front Dana 60, tubes fully welded and gusseted, Hyraulic steering, NWF high steer arms, dual triangulated 4 link, upper links are 1.250" OD x . 250" wall DOM with 7/8 FK Rod ends, lowers are 2" x .500" wall DOM w/ 1.250 FK Rod ends, solid Spicer 1410 U-joints in drive shafts, one each complete extra-upper link/lower link/drive shaft, 205 LOWMAX 3:1 t-case, stainless twin stick shifter, TH350 with TCI full manual reverse valve body with engine braking, Coan hardened 1st gear planetary 1.75:1, 2000 stahl conv., rock gate shifter, dual pass trans cooler with fan, 2000 4.8 LS with 112K FI stand alone, MSD LS conversion fuel pump/filter - also extra pump, dual Magnaflow stainless mufflers, factory accessories, 2500HD power steering pump, alternator, and clutch fan, dual pass aluminum radiator, 15 gallon aluminum fuel cell in rear of tub, 16" ORI nitrogen struts, 38.5 x 14.50 x 15 TSL SX's on 15x8 Bart bead locks with matching spare, PRP seats and 5-point harnesses, long bikini top and full soft top, half hard doors with soft uppers, LED lights front and rear. Rig does great all around, rides smooth, steers good, eally hate to sell it due to built the way I wanted it and having so many hours envolved, just can't get guys to go often enough to justify the money I have in this rig.
Located in Terre Haute, IN 47805 Asking $18,000 call/text 812-two5one-two1two9 leave message, possible trade for crew cab Duramax, 99-03 Hard top Corvette, 60's Chevy muscle car
CONS, stock cage with add in front bars, tires are starting to dry crack some due to age but have always been inside and hold air well. Currently working on rock slider/nerf bars to tie the skid plate to the frame.
Re: 2000 TJ Trail rig
Sent from my SAMSUNG-SM-N920A using Tapatalk
Hotrodfry said:
2000 TJ with title,
Located in Terre Haute, IN 47805 Asking $19,000 call/text 812-two5one-two1two9 leave message, possible trade for crew cab Duramax, 99-03 Hard top Corvette, 60's Chevy muscle car
GLWS
