Sold/Expired 2017 angryfab rock bouncer
Not that any of you asshats would take my word on it, but I have seen this buggy a couple of times. She is a bad bitch for the money :****:
423488fiveseven54
text them to me and i'll upload them for you.... after I have some alone time with them
And more?
Sent from my SM-S903VL using Tapatalk
Now that Kel has posted up some pictures, how about some specs to complete the ad? :dunno:
ADMINISTRATOR
Motor.
De stroked 454 or 427 which ever you want to call it
.060 over with dom top pistons
9.5 to one it will run on 93
All forged rotating Assembly
781 heads with big valves roller rockers
Elder Brock intake on pane
165 amp alt.
Psc high flow tc style power steering pump
March pulley 5 rib
Motor has very quick response
Lot of torque
I will finish up the rest in a little bit
I'm at work an I will get in trouble of I get bought playing on my phone to much
Custom 2 quart power steering Reservoir an custom pump bracket so it will be up out the way at full stuff
It has a th400 with a rev manual valbody
3.0 atlas transfer case
Chevy Dana 60 front an 14 bolt rear
Welded rear
Spool front
4.56 gears
Rear Spicer
Front Yukon
35 spline rcv
Custom keyed knuckles
For cooling
Champion 4 core 32x20 radiator
Flex -a-lite 495 duel 15in fans with Thermostat controller you set the temp you want them to come on an they come on at 60% an ramp up to 100%over the next 10 degrees max out at 4600 cfm an I put a over ride switch on the dash
Links are 2in 1/4 wall Dom with Industrial Himes weld in and you do not have the Teflon in them to ware out an the shaft on them are a true 1in and 1/2 shaft so super strong an you don't have to worry about jam nuts .
1in bolts
