Sold/Expired 2016 EOR Ultra4/buggy (SOLD)
dynajeep
Boyne City, MI
Going to sell the buggy, need to step back and focus on home life.
Several trade offers and people asking what bottom $ is. Price dropped to bottom $ and not willing to deliver. I've put over $50k into this buggy this year. My opinion it's the best running handling buggy out there for the money.
Ultra 4 tagged, Cad designed laser cut subframe fully tig welded which incorporates link mounts, crossmembers and skid. Powder coated with hammered silver vein
Bendtech designed chassis DOM/Chromoly mixture .188 lower frame rails .120 everywhere else
3/8€ 6061 aluminum full skid
€ Front Axle
Ruffstuff 9€ fabricated housing with Ruffstuff truss
Brand new Gearworks HP10, 35 spline spool, forged 1350 yoke, fresh seals, RCV inner axles with 300M bells and outers, all 300m spare RCV's along with spare 300m bell, Reid inner C€™s and outer knuckles, Reid bronze kingpin bushings, Stage 8 locking spindle nuts
Artec High Steer Arms, Artec Ram mount, Yukon hardcore hubs & spindles, EBC Chevy ½ ton drilled/slotted rotors and pads, NWF drive flanges.
Rear Axle
Ruffstuff 9€ fabbed housing €" Ruffstuff backbone and truss, Gearworks TT 10€ third member, spool. Installed with bolts from inside the housing, lock washers and top lock nuts €" never worry about the third coming loose. All new seals throughout, Amsoil gearoil, Full float RCV 300m shafts, with spare RCV 300m shafts, 14 bolt spindles, Ballistic fab aluminum 14 bolt hubs with keyed drive flanges, EBC Chevy ½ ton drilled/slotted rotors and pads
€ Engine
Brand new LT4 crate motor, ATI 15% crank pulley, Holley pan and baffles, Drive Junky accessories drive pulleys isolates blower from water and steering pump. Custom stainless water neck 3d printed. All work done by the master Chris Roes. Tuned in by Justin May of Indiana Muscle. Made 398hp and 396tq to the wheels. Everythimg about this setup was done to be ran in the King of Hammers, so cooling and everything is overkill.
Holley dual dominator fuel pump with hydromat pickup, fuel shut off valves, all AN fittings and hoses
€ Transmission
Maximum offroad built TH400. REID case full ultra 4 build, 300m input, strait cut planets, billet converter
PRC cooler with dual Spal fans
€ Transfer Case
Atlas 2.0 with 300m gears from the famous 555 racing Unicorn!
Wide Open Design built driveshafts, .250 wall. Spare RCV Chromoly HD driveshafts front and rear built by EOR
€ Suspension
4 link rear with CNC milled trailing arms by Branik, FK 1.25€ heims , 2€ 7075 upper links
4 link front with 7075 Aluminum links, FK 1.25€ heims PAC racing springs
PAC Racing Sway bar
Radflo 2.0 coilovers, 2.5 4 tube bypasses in the front and 3.0 5 tube bypasses in the rear, also 2" bumps in front. Tuned by the #shockjesus Phil Licciardi
€ Steering
PSC XR series CBR pump with external relief valve, PSC XR Remote high flow reservoir and 11.3 steering valve, Howe TT inline cooler, PSC XR series 2.5x8€ DE Ram €" all AN hose, Longacre steering wheel with splined double safety clip quick disconnect
€ Miscellaneous
PRP Podium seats and 5.3 ratcheting harnesses
Wiring was all done by Patrick Parker €" mil spec wire & IP67 automotive connectors. Top of the line everything, sealed switches
5 brand new 40" treps with 5 brand new Trail Ready beadlocks also have 4 new 43" tsl sx stickies on racelines
Rugged radios 357 intercom
Rugged radios dual fresh air pumper kit with hoses
Sidewinder shifter
Edge CTS2 for gauges
Odyssey PC-1500-DT Battery with Ruffstuff mount
Jaz 22 gal fuel cell with Artec mount, remote fill kit
PRC 31X19 radiator with -16 AN fittings and dual 14€ Spal fans
Wilwood dual ¾€ master cylinders with Wilwood pedal
Kartek siren
Aluminum interior with Custom Tint & Offroad bedliner
Custom built Mastercraft window nets
Warn VR-8000 winch with synthetic rope
Tusk LED interior light, ridged industry rock lights, first aid kit, break down triangles
Retractable ratchet straps for holding down tool box/cooler
Brake line lock parking brake
$65,000
Boyne City, MI
Call/text 231-675-3930
Will consider selling minus motor. Will deliver for full asking price anywhere in the country
Sent from my SAMSUNG-SM-N920A using Tapatalk
Re: 2016 EOR Ultra4/buggy
drool drool drool That's all I got to say.. drool drool drool
ADMINISTRATOR
Bump for one bad buggy! Won't find a better deal on this level buggy right now in my opinion
smbroady82 said:
I miss being able to drive 5 min down the road and drool on this one
Thanks guys! Have a few people interested but nothing solid. Everyone wants to know bottom dollar, it's $65k.
Trailing arms are being built this week. 7075 billet with 3/8" stainless braces where the shocks bolt together. No more trailing arm issues. Post updated to bottom $ price.
New trailing arms are in and a fine tune with Phil this weekend on the shocks. Buggy is running awesome!
Was gonna message you but I can see they're scratched. GLWS ;)
