Sold/Expired 2015 ATC Quest all aluminum enclosed trailer ready to haul your 4x4
knaffie
everywhere
• 2015 ATC Quest. All aluminum everything, all tube construction, best build quality on the market.
• 8.5' x 28' with 7' ceiling (6" extra height from standard).
• Tandem 7K Dexter torsion axles with brakes on both.
• 235/85/R16 load range G tires – you won't overload these!
• Extruded aluminum floor and ramp with full length double e-track + 4 heavy duty tie-down rings.
• 60" long storage well in floor is perfect for heavy items like driveshafts, axle shafts, gears, floor jack, etc.
• Custom cabinets will hold all your tools and supplies + a wardrobe cabinet to hang things up.
• Lots of super-bright LED lights inside.
• New VIP 3500 power tongue jack (USA-made high quality unit).
• Toolbox on front is great for storing spare fluids and anything else you want and also contains a newer deep-cycle battery and shutoff switch (runs the lights for days without recharging).
• Custom 3/16" steel platforms over wheelwells so you can drive / haul your 4x4 on them. They are removable if you don't want them.
• 48" wide RV style side door with inside/outside lock.
• All LED exterior lights with two sets of tail lights.
• Identical spare tire mounted conveniently inside where it's easily accessible when loaded.
• Blue Ox Sway Pro mounts on the tongue.
• Will hold a fullsize 4x4 on 40" tires + two ATVs with room to spare.
• Absolutely no oil/gas/chemical smell inside. We sleep inside it often and religiously scrubbed the floor and wiped the walls whenever it was dirty. I don't believe it has ever touched the road salt.
• It's in great shape overall with no major problems (I'm OCD about keeping my stuff nice), but it's not perfect. A few minor dents inside and out. Two ceiling panels near the back are in rough shape where my Jeep's cage rubbed it going down the road when a strap came off. These panels can easily be replaced (held on with double-sided tape). One cabinet door has a dent in it that could also easily be replaced.
• I have about 40 current pictures and all the prints from ATC I can email or post – just ask.
• Trailer is currently in Fort Myers, Florida, but I can help deliver anywhere. Anywhere on the road between Florida and Michigan delivered for no additional cost if you wait until late April when the new trailer is done.
• I'm $28,000 into this with all the extras. I'm asking $19,000 (negotiable).
outside pics
inside pics
more inside pics
prints 1
prints 2
rear door opening: 90" wide x 85" high
58.75" between wheel box covers
11.5" floor to top of wheel box covers
262" rear door to back of road side cabinet
310" rear door to front cabinets
84" floor to ceiling
