Hardline Crawlers
March 21, 2019, 12:00:55 PM *
Pages: [1]   Go Down
  Print
Author Topic: Jeep YJ & TJ Grill Hoop front bumper with rockcrawler rear package  (Read 657 times)
motobilt
Offline Offline
"I Build Stuff"
WWW
« on: January 15, 2018, 09:46:55 AM »
YJ & TJ GRILL HOOP FRONT BUMPER WITH REAR BUMPER PACKAGE
The Motobilt Jeep YJ, TJ, or LJ front bumper is the most versatile yet.  This bumper like our others is made out of 3/16" thick steel plate that is laser cut and CNC formed in house. The bumper has a modern sleek design that sets it apart from the competitors.  The bumper features not only a built in winch mount but also the fairlead mount.  The new bumper fits up and over the factory sway bar.  So you get the look of a recessed winch but you do not have to modify any of the existing Jeep components.  The bumper shown here has the optional grill hoop and stinger.  This new bumper allows us to weld the hoop directly to the bumper above the factory sway bar mount.  Another important feature is that the grill hoop ends up being completely vertical and does not lean like some other bumpers on the market.
Features:
Made in the USA
3/16" Laser cut and CNC formed bumper
3/4" thick laser cut D-rings that are welded inside and out
Built in winch mount and fairlead mount
Grill hoop, stinger, and support bars all made out of 1.75" DOM tubing
Bolt on design
Works with factory sway bar or anti rock sway bar.
Front slots act as a lifting point for a high lift jack.
Hardware NOT included
Motobilt products are MADE IN THE USA. We weld out each bumper here at Motobilt paying close attention to detail. The Motobilt rear bumper for the Jeep CJ, YJ, or TJ was designed with function in mind, and we made it look cool also. The rear bumper fits tight to the rear of the Jeep. The bumper is fabricated from high strength 3/16" thick steel plate. The parts are formed on a press brake and welded where required. The bumper features a 2 inch receiver hitch for taking a rear mounted basket along on the trail if needed. The bumper also features two d-ring mounts for recovery points. The d-ring mounts are 3/4" thick high strength steel. Like the other Motobilt bumpers the d-ring mounts pass through the bumper and are welded on both sides. The bumper is the perfect match for our Motobilt 42 inch Rock crawler front bumper or our competition front stubby bumpers. This bumper is shipped bare metal. The bumper does not include a tire carrier.
« Last Edit: January 15, 2018, 09:47:58 AM by motobilt » Logged
Dan DuBose "I build stuff!"  Bobby Cox "I sell the stuff Dan builds!"
MOTOBILT
www.motobilt.com
motobilt
Offline Offline
"I Build Stuff"
WWW
« Reply #1 on: March 08, 2018, 02:17:16 PM »
www.motobilt.com
Logged
MOTOBILT
www.motobilt.com
Pages: [1]   Go Up
  Print
Jump to:
