Sold/Expired FORD SUPER DUTY DANA 60 LOWER LINK MOUNTS
motobilt
"I Build Stuff"
Dothan, AL
MOTOBILT FORD SUPER DUTY DANA 60 LOWER LINK MOUNTS
The Motobilt Ford Super Duty Dana 60 lower control arm mounts are just the ticket for that custom suspension setup. This heavy duty 1/4" steel brackets are laser cut and cnc formed at the Motobilt headquarters in Dothan, AL. The will allow you to mount a rod end, flex joint, or other end that has a mounting width of approximately 2 5/8"s wide. They are available in iether a 9/16" bolt hole or a 3/4" bolt hole simply by choosing from the drop down menu.
What makes these brackets unique is there mounting width at the axle tube has been necked down to fit on the small amount of axle tube available. You will still need to cut away much of the brackets and cast housing to make room for the mounts but this is a pretty common procedure when attempting to use the newer 2005+ Ford super duty axles.
These brackets are sold as a pair and will need to be welded.
