Sold/Expired 1987 yj crawler
09zkrankin
catlettsburg KY
1987 jeep yj rock crawler, this jeep was built to handle whatever you throw at it. Dana 60 front axle, locked, with chromoly shafts machined for full circle clips, 35 spline chromoly outers, ecgs chromoly drive slugs, 3/8 diff cover, hydraulic assist steering, .250 wall DOM tie rod, 14bff rear axle, trussed, 3/8 diff cover, pinion support, disk brakes, locked, stock shafts. 1350 driveshafts.
Engine is a 5.3 from a 2002 chevy truck with just over 120k miles, doesnt smoke, just standard lifter noise. Th350 transmission, shifts good, np241c transfer case with jb conversions super short sye, 32 spline outputs, chromoly 1350 flange on rear
Suspension is 4 link in the rear with 2"x.250 wall links with 1.250 chromoly heims. 18" travel fox 2.5 air shocks. Front is wagoneer leafs outboarded for the dana 60. Wheelbase is about 113"
Tires are 40" super swamper ltb with about 80% tread, on 17" weld on beadlocks.
Has full cage tied to frame, seat mounts are incorporated into the cage as well as harness mounts. 15 gallon fuel cell, all lines done with an fittings and aluminum hard lines. Aluminum radiator, steering box brace. 9k winch with synthetic rope and billet fairlead. Suspension seats(need new covers) cam lock harnesses. Led rock lights all underneath, led interior lights, led cubes on bumper and 20" led bar on the cowl
Jeep has some trail rash, but is a well proven rig. I have wheeled it all over with great luck amd am taking a huge loss on it as i have found something else i want.
$8000 cash, trade value will be higher. I have over 12k invested and the price will go back up if what im looking at sells. Located in cannonsburg ky
You can call or text me at 606 585 2212
Sent from my SAMSUNG-SM-G890A using Tapatalk
