motobilt
"I Build Stuff"
FORD SUPER DUTY DANA 60 TRUSS
MB4076
The Ford Super Duty Dana 60 truss from Motobilt will greatly increase the strength of your front axle. The main structure of this axle truss is laser cut and cnc bent from 3/8" thick steel plate. Supporting the main truss are 3/8" and 3/16" structural bracing. The top portion of the truss is aproximately 5.5"s wide and provides ample room for a suspension link mount to be welded onto it. Can be used for a 3 or 4 link setup.
Features
3/8" thick laser cut steel plate main truss
3/8" & 3/16" steel plate support structure
Full length span of axle for increased strength
Large flat mounting surface for link brackets.
Notes:
Requires removal of factory brackets and housing on driver's side must be trimmed approximately 2"s.
MB4076
Features
Notes:
