Sold/Expired Coleworx YJ juggy
kmcminn said:
I'll give 500 for the chassis and extra grill and come pick it up.
. Drop it off in Ft. Payne on the way back home, and I will give a thousand. Everybody makin money..... :JRich:
Chassis 2000.00
Ballistic fab joints and links 12 joints total 500.00
Axles Dana 60, hd70, 2000.00
Wheels and tires 2500.00
Coil overs 4x150, 2x250,2x200, 2000.00
Engine summit racing 383, 450hp with Edelbrock FI, 3000.00
Trans 700r4, 700.00
Transfer case with shifter, 300.00
droldz said:
2000.00 for the chassis and you could be rocking this hood.
2k chassis with sheet metal ? You have my attention sir, it's in Missouri ?
Edit:. Just went through your Photobucket acct and it looks like the chassis ( specifically the front stinger ) has been cut on etc. I would be highly interested in this right with the front clip and all. Very big fan of Bryan's work. Probably as close as I would ever be to being able to own one :dblthumb:
It's in Southern ILL. Nothing has been cut on except rear link mounts on frame as far as I can tell. Have someone local interested in the chassis.
Still have everything!
droldz said:
Chassis 2000.00
Ballistic fab joints and links 500.00
Axles 2000.00
Coil overs 2000.00
Engine 3000.00
Trans 700.00
Transfer case 300.00
droldz said:
Chassis 2000.00
Trans 700r4, 700.00
Cage is part of the chassis. No links included these links are from another build. Will include dash, anti rock, misc wiring, heater box, skid, fuel cell and column.
Your killing me, I've been thinking hard and heavy about this chassis. Have any better pics of how it sits right now ? It does have the panels and grille parts it was originally built with too ?
Has everything that i got it with no links, shocks,drivetrain,seats shifter or steering column did change hands several times, but appears to all be close to the way it was built. I removed the cage and tub that all bolts together rear link mounts were removed, fuel tank had the in the tank pump mount removed otherwise the same.
All the other parts are from another Jeep broken down to build this chassis.
droldz said:
This is a project built that never got finished.
Comes with daully Dana 60, crane outers, Yukon shafts with super joints
, 4.10 gears, full hydro steering Dana 70 HD with disc.
Summit SBC383 with alm heads and Edelbrock fuel injection, pump and wiring included, 700r4 trans, 300t/c some driveshaft parts. King coil overs 16" with springs. 5 Trailworthy H1's, pvc centers with 39.5 Pitbulls
Comes with a CJ grille and original coleworx YJ grille
Old sale add on Pirate.
https://www.pirate4x4.com/forum/vehicles-trailers-sale/794873-coleworx-built-yj-buggy.html
12000.00 obo. May part out also.
Located in Southern ILL
So are the coilovers 14" or 16"?? You have 16" listed in the first post but said after they were 14". Just want to clarify thx.
