Sold/Expired SOLD Blue Torch Fab 3 Seat Fusion Buggy (Michigan)
Status
Not open for further replies.
RKCRWLN
Member
White Lake MI 48383
SOLD
BTF 3 seat chassis with TJ hood, grill and Fiberglass cowl
5.3 LS Motor, TH400 transmission with winters shifter (rock crawl pattern), Stak 2 speed (4:1) transfer case, Aluminum radiator / shroud and electric fan. Stand alone wire harness that is not botched together.
78/79 Dana 60 kingpin front axle with Detroit locker, chromo 35 spline shafts and drive slugs. Dana 60 rear with locker also has 35 spline with 5.38 gearing.
4-link front and rear (double triangulated rear, parallel upper and triangulated lower in the front) Lower links are aluminum. 2.5 Radflo coilovers with remote reservoirs on PAC racing springs
110" Wheel base / Belly 22.5" / 81.5" height / outside width front 88" & rear 85"
1410 newer front and rear drive shafts,
Chevy 3/4 ton disc brakes on all corners
42" Pitbull Rockers on Trail Worthy Fab / TWF 16.5 wheels with PVC inserts
3 corbeau seats with 5 point harness
Mojave Heater (2 speed) makes the wife happy
PSC full hydro steering
Warn 8000 winch with 75' rope and ATV winch in the rear.
12V guy switches (Ign, start, lights, heat, F&R Winches, Rock lights, Led bar) and rear blinkers
Tons and Tons of custom work went to this buggy including an all metal 2 piece roof. Titled as a 1980's Jeep wrangler in the state of Michigan. I will help with getting it onto a shipper on my end if needed. This buggy has proven itself many times over and it will not disappoint you. Ready to wheel needs nothing
$26.5K OBO The only trades I would look at are for JK / JKU Rubicon or LJ Rubicon.
The Jeep / Buggy is located in White Lake Mi 48383
Re: Blue Torch Fab 3 Seat Fusion Buggy (Michigan)
Other than the tires, this thing is the tits! Way cheaper to buy than build it.
Any pics from the front? Cool ride!
How tall of a driver is it set up for?
Whats the details on motor and tranny? Built? Stock? Miles?
Motor is stock with headers and has around 82K miles. Transmission is a turbo 400 and it was rebuilt when put in. It was built by Tranny Tom
So much want.
I like the bike grips for the third seat. That's a pretty good idea.
Pm sent
A few pictures trying out the MetalCloak trailer at the beginning of summer at AMW4X4 open house
Status
