Sold/Expired 4 seat Yota buggy
ranger11
Started life as a 84 model extra cab that was cut up to haul the family around in.
22r with got propane kit, two tanks, gm one wire alternator.
Dual stock cases has tcase brake(not hooked up)
Front axle has 5.29 yukons with 29spline pinion, yukon grizzly locker, rcv shafts, trunnion bearing eliminator's, trail gear high steer, Truss and diff guard.
Rear axle is an ifs axle with 5.29s and a spool tg disc brakes and diff guard.
Has square tube front shaft and 2" .25 wall rear shaft.
Like new (only 3 rides) 38x12.50x15 sx's, with diy beadlocks. No leaks.
Front suspension is the rears springs and in the rear are chevy 63's with tg shackle mounts.
Has a older harbor freight winch, it works but is slow, has rope and is wired in cab.
The interior is basic, stock dash and gauge cluster. Front seats are smittybuilt with prp harnesses, the rear seats are rzr seats with prp harnesses. The rzr seats are a little stained on the white part I planned to paint.
Few misc things, alien gear sun shade on cage, nice door bags, wide angle rearview mirror, grant steering wheel, led head lights and led light bar. Has a fj master cylinder, and all pro cross member. Also will come with a cover that keeps it dry/ out of the weather. Also have window nets for the rear openings.
Its a nice rig the parts aren't beat up and wore out, rides good, runs good, and crawls good. The only thing it needs soon is leaf spring bushings installed they make a little noise. The cage paint needs to be touched up from where I rubbed it on a rock. Exhaust manifold has a leak but I have a new header I plan to install.
6000 obo may trade for ATV or older sxs plus cash
Located in Warner robins, Ga. I will have it at Fall crawl at River Rock on the 29th if you want to check it out.
Re: 4 seat Yota buggy
Good going rig
I second that! It's is definitely a beast! Very well built! Glws... if I don't snatch it up first..
6500 and will throw in a new trail gear full hydro ram.
Sent from my XT1635-01 using Tapatalk
6300 obo will meet half way as long as you live in a southern state.
Replied
Yes heat works good
I will get them pics for you this afternoon.
Here's a few pics let me know if you need or want more.
Re: Re: 4 seat Yota buggy
slikwilly said:
What kind of legroom does it have?
I'm 5'10 and really need the seat moved up an inch or two. I was gonna extend the clutch pedal. For the record I'm 5'10 and 280lbs. So I gotta have clearance in the middle. The seat could go back if you need it to. However I've set seats up for a 6'2 guy and it didn't feel as far back as these. Your more than welcome to come see how you fit.
Oh okay. Let me see what I can do. It looks like a well built rig, and I like that it has 4 seats! Never had a rig with propane though. Im sure it has its pros and cons like everything else. Thanks for answering my questions. Hope to get in touch with you soon. Thanks.
The only con I have with propane is getting tanks filled. It's not as common as a gas station. I wheeled chocco and Morris on one tank(two, two day trips) and used one tank at harlan which was a 4 day trip. I was really impressed with fuel consumption with it.
I can vouch for the build quality. It IS very well built, and it will GO! You will be very hard pressed to find a rig like this and this well built for this cheap... ????????
Thanks for the compliments.
Installing the new header and exhaust tonight. May try to re paint the cage before next weekend.
Gonna put on the book of faces soon. Really would rather deal with someone from here. Make offers but please know I'm not gonna take 4500 and drive 12 hours...
Don't forget I will be at River rock with this and your more than welcome to test it out.
