ECGS
url=https://eastcoastgearsupply.com/i-23993625-gm-14-bolt-rear-axle-30-spline-shaved.html]https://eastcoastgearsupply.com/i-23993625-gm-14-bolt-rear-axle-30-spline-shaved.html[/url]
The ECGS 14 bolt features the highest quality parts available on the market.
The base price includes:
Brand New 14 Bolt Center Section with 4" x 1/2" (.500") DOM tubes. Housings come bare with chromoly spindles ONLY! TRUSS NOT INCLUDED!!
This axle is designed around a stock 14 bolt using upgraded parts, you can re-use your current brakes, hubs, shafts.
Choose your options below to outfit your axle the way you want it built. If you don't see an option listed feel free to contact us and we can provide an estimate.
Add Locker or Spool:
Select your choice between an ARB Air Locker, 30 Spline Spool or Yukon Grizzly Locker (Includes New Carrier)
Add Shafts:
Chromoly 30 Spline Axle Shafts
Differential Cover:
Full 2" shave cover (requires shaved ring & pinion) select below to have the bottom plate welded or shipped loose.
Select Gear Ratio:
We use the highest quality ring and pinions along with Timken bearings, this price also includes a solid pinion spacer. You must select a locker or spool for this option!
WMS
We have five popular options for wheel mounting surface (WMS). 63", 65", 67", 69", 72"
Availability: TYPICAL SHIP TIME IS 45-50 DAYS FROM DATE OF ORDER!!
