Sold/Expired 2018 WIDE OPEN DESIGN SINGLE SEAT RACE RIG 70k
ratedX
One off single seat Wide Open Design single seat chassis. Buggy is extremely capable and a very detailed build with no expense spared. Comes with 4 cut stickies,2 cut ag tires and 40 gallons of 116.
Motor: New venom racing fully forged 427 ls3. 14.5 to 1 compression. Slick Rick ported dart pro 1 heads. Can give full motor build to serious buyer.
Tranny: New Ptc turbo 400. All billet goodies. 4200 transmission specialties converter.
Transfer case: SCS straight drive case. 3.33 ratio. Billet 1480 drive flanges.
Brakes: Ouverson pinion brake with willwood 4 piston caliper.
Axles: Wide Open Design 40 spline 14 bolt front. Rcv axles. 4 inch .500 wall tubes. E.73 gears. Rear 14 bolt Mark Williams 31/40 spline shafts. Spools front and rear.
Suspension: Fox 2.5 triple bypasses. Fox 2.0 coil overs. Wide OpenDesign trailing arms. 2.5 7075 lower links. 2.25 uppers.
Wheels tires. New cut stickies 1 race. Trail ready beadlocks.
Driveshafts: 1480 .250 wall built by pem racing. All billet drive flanges
Steering: Howe trophy truck system done right. Everything mounted as should. 2 turn lock to lock. Wicked fast.
Sway bar: Custom 40 spline sway bar with 7075 arms and hardware.
Cooling: CBR monstervradioator with upgraded Spal fans. Derale heavy duty tranny cooler with spal fan.
All wiring was done by Jesse over at level seven and it is as clean as it gets. Holley dominator fuel injection. Has 4303 magna fuel fuel pump and regulator. All hoses are braided not one hose clamp used. Battery is 21lb Brailey race battery. Fuel tank is 15 gallon. Header ware built by me. 2inch with 4 inch collectors. All hardware is grade L9 Allen head. Buggy is a super clean and we'll built would be top contender with a driver. Any questions call 3146301990
UNION MO
THis is a BADASS MACHINE MATT. I know you took a tumble at that one race with it, but looks brand new now... GLWS
ADMINISTRATOR
Dam you ****er I ain't even seen this bitch in person and your already trying to sell it
