Drive by wire pedal water proof?
30th6
florence al
I have a dbw pedal in my buggy and it's not protected from water/dust. Are the pedals water/dust proof? If not what would you recommend to seal it up?
Dbc is not a option
I just replaced mine after trying to troubleshoot some crazy symptoms. It would cut out bad over 5000 rpms and then go into limp mode.
Took 5 years of wheeling and pressure washing to go bad but it did appear to be corrosion that took it out.
Throwing code: P2138 throttle/pedal position sensor/switch D/E voltage correlation
Ok sounds good I may try and find a thick balloon or something similar to put around it. Thanks
