MihlfeldL2005
- Joined
- May 2, 2014
- Messages
- 192
Up for sale are a couple of axles that I've been working on for no apparent reason. I picked these up with the intentions of going to full hydro/possibly building another rig but I've got another project that I want to dive into so these need to find a new home.
Here's the build list. I'm sure I'm forgetting a few things but these are an EXTREMELY good start to a very stout set of axles.
1978 Ford Dana 60 Kingpin
5.38 Yukon Gears
Yukon Grizzly Locker
Yukon 35 Spline Stub Shafts
Mile Marker 35 Spline Selectable Hubs
Artec Full Hydro Truss
Crane High Steer Arms w/ Aluminum Caps
Motobilt 3/8 Diff Cover
Full set of new bearings and seals
1350 Yoke
New Brake Rotors
New longer Wheel Studs
Entire axle has been sand blasted and primed/painted
Truss is tacked on, will need finished welding
$2500
Rear is a 14 bolt SRW (15 Bolt now)
5.38 Gears (shaved)
Mini Spool
Full shave kit with the welded plate and cover
Artec Full Truss w/ Pinion guard and bridge
Artec Backbone Truss
New Longer wheel studs
Ruffstuff Full Disc Brake conversion kit
Stock Shafts
1350 Yoke.
$1500
pictures....
https://drive.google.com/drive/folders/1XVHAV-LgxqsUTFzR-XA1lPvRbrTHYeJx?usp=sharing
Axles are located in Fowlerville, MI I'm heading to Ft Rucker, AL at the beginning of December, can arrange delivery. Please feel free to ask any questions you might have.
5.38 Yukon Gears
1350 Yoke
New Brake Rotors
$2500
5.38 Gears (shaved)
Mini Spool
Stock Shafts
1350 Yoke.
$1500
pictures....
