Trailbouncer #09 Uncle Tito
Re: Trailbouncer #09
TBItoy said:
Honest question,
Why does the dash area look so "tall"? like the cross bar is up at almost to neck level?
Cause corbeau seats are made for midgets . The top of the headrest is at the base of your skull most likely...
Trailbouncer #09
Getting the woopow maker buttoned up for #9.
Still not sure what way to go with engine management. DBW, DBC, stock E78 ECU, E38 ECU, Holley EFI?
I'd put pure race gas with a little piss and vinegar in it. Drive by foot is all that's needed.
Sent from my XT1635-01 using Tapatalk
A bunch of small things done lately, Seats/harnesses in, bumps, sway bar, finished up the door bars, started on the exhaust..
Beautiful work !
74weld just came out with this. I got one for my buggy and its a nice piece.
Getting down to the little things before the aluminum works gets started. exhaust is all tacked up, orbital/steering column and brake pedal hydroboost mounted.
Getting it off the table was fun. Got the an fitting and block off plate welded on the water pump. Chassis is all welded up and ready to go back together to a roller.
Molly Hatchet said:
IRONDUCK INDUSTRIES does great work!
Thanks Ryan!
Got it welded out and mostly reassembled. Still have to build the engine cage and cooler rack when it gets back from getting the tin work done.
Makes me want to build a new chassis. Looks tits
Sent from my Pixel 2 using Tapatalk
TBItoy said:
Honest question,
