Ghetto limit straps
Eddyj
Birmingham
The rear of my buggy is tall. I've never had limiting straps but like the ideal of them going from mounting points of the coilover. So I need a 35-40 inch strap.
Which will take a week to have shipped.
I am not opposed to rigging some crap together and beating on it.
So has anyone seen or had a good ideal for ghetto long limit straps?
been using synthetic winch line or 1/2"polyester boat rope. just splice it to lenght.
winch line doesnt have too much flex so you can feel it .
polyester boat rope has nice amount of flex so it stops the axel softly.
currently running red 1/2" boat rope rated to 8k lbs. they been there for couple years four corner cost is like 15$
picture.php
picture.php
This is a good ideal. I was hoping something like this would pop up. I ordered some regular straps in the correct length but I love seeing budget solutions that work. I like the slider I may incorporate that in with new straps as they will be long.
picture.php
Eddyj said:
I'm not sure how "ghetto" translates. But you nailed it sir.
guy creeping in the background has his hat on backwards to certify the authenticity of this ghetto job! :stir:
I will have to hold out for a closer picture of the lower attachment point - looks like a 5/8" nut welded to the axle in place of an actual lug, but need a closer picture to confirm the true "ghetto" worthiness! :popcorn:
I use amazone axle straps....4/$24....24" long. I weld a plate into the eyes for a 1/2" bolt, but you can use eye straps too. Work well for slow crawling....not sure I would put them on a desert truck or monster truck...
snag a lap belt out of the back of a junk yard car, it already has bolt down points, is adjustable, and is easy to disconnect when you need that extra half inch. "thats what she said" :cougar:
I can tell you from experience, do not tie the limit straps into the coilover bolt, I bent a many of 1/2" bolts that way and luckily caught them before they broke and took out a coilover. just buy the quad straps as they really do not stretch.
think poly performance has them the cheapest and I believe it is pirate10 that gives you 10 percent off
