Hardline Crawlers
June 18, 2019, 10:34:25 AM *
Pages: [1]   Go Down
  Print
Author Topic: Breaking bell housings, need help  (Read 900 times)
30th6
Offline Offline
« on: April 15, 2019, 12:23:19 PM »
I was pulling the engine today and noticed the bell housing is broke . Every single mount is poly.  Is this just a fluke or am I gonna have to pull this pos outside and burn it to the ground.
5.3, th350, 205.
Logged
Caddy Buggy, 5.3, th350, 205, 60/14, 42s
TBItoy
Offline Offline
« Reply #1 on: April 15, 2019, 12:37:12 PM »
if it's gonna flex, it need to be a mounted in a triangle.
Logged
Nick Cooper - Dodson Branch, TN
Contact  -   EAT.SLEEP.WHEEL@GMAIL.COM
Bebop
Easyline Crawler
Offline Offline
« Reply #2 on: April 15, 2019, 12:41:41 PM »
Agreed.
Also, the bellhousing bolts have to be tight.
My TH400 bellhousing broke in the exact same spot and the only bolt that wasn't tight was this one, around the break.
Looking at your mounts,  I would remove the dual poly mounts on the chassis side and replace them by 1 directly under the transmission..
Logged
Wandering Frenchie.
Living the dream in the USA !!
Quote from: pholmann
You just wish you had a sexy bald head.  Flip Off
the_white_shadow
Offline Offline
WWW
« Reply #3 on: April 15, 2019, 12:54:33 PM »
I have an empty th350 shell that id sell if you need it.
Logged
--Alex
The Dirt Squirrel - '82 Toyota - LQ4/4l60e/4.3Atlas/D60/14B/5.13s/RCVs/Reids/43" SX Stickies/Linked/Locked/Awesome
http://www.pirate4x4.com/forum/toyota-truck-4runner/774031-my-82-first-gen-project-dirt-squirrel.html
30th6
Offline Offline
« Reply #4 on: April 15, 2019, 01:08:57 PM »
I'm not sure I'm tracking on the triangle. Can you explain the mounting points
Logged
Bebop
Easyline Crawler
Offline Offline
« Reply #5 on: April 15, 2019, 01:19:08 PM »
On the left is what you have currently.
On the right is what you should have.
Excuse my Paint CAD skills...
Logged
Wandering Frenchie.
Jduck
Offline Offline
« Reply #6 on: April 15, 2019, 01:31:33 PM »
Right now your basically solid mounted with the bushings so far apart.  When the frame flexes it’s twisting the drivetrain and breaking the case.  Like said above move the trans bushing to the center and if you can move the engine bushings from the frame down to the block that’ll help as well.
Logged
30th6
Offline Offline
« Reply #7 on: April 15, 2019, 02:42:36 PM »
Ok I'll move the trans mount to the center, but what about the t case mounts. Won't those keep it from twisting also? I have a mount on the pto "driver side" and the rear cover on the 205.
Logged
zukimaster
Offline Offline
Hold my beer and watch this!
« Reply #8 on: April 15, 2019, 07:28:06 PM »
You can cut that bell off and install a J&W bell housing.
Sent from my Moto Z (2) using Tapatalk
Logged
Tin Top Sammy under construction, Chad, Ft. Payne AL
POR
Offline Offline
« Reply #9 on: April 15, 2019, 08:06:57 PM »
Your to rigid.. just let the case hang off trans like it was designed too. You only need a single mount under the adapter.
Logged
infamous1
Offline Offline
« Reply #10 on: April 16, 2019, 03:30:09 AM »
That J&W bellhousing also doubles as a scattershield. It is a nice part, I put one in my buggy. Just be careful cutting old one off or you will have an extra fill hole in the case shit
Logged
don't snatch
30th6
Offline Offline
« Reply #11 on: April 16, 2019, 05:15:25 AM »
I broke the back off the last th350 doing this.
Logged
30th6
Offline Offline
« Reply #12 on: April 16, 2019, 05:36:27 AM »
I may try this also. Sounds cheaper than building a new trans to
Logged
tallnate
Offline Offline
« Reply #13 on: April 16, 2019, 08:31:58 AM »
yeah I would say support the rear of the trans in the center with a bushing mount and remove your current case mounts.  But since th350's are known for breaking at the tail housing I'd run a rear center case mount similar to this.
https://www.bing.com/images/search?view=detailV2&ccid=nDhOt8mY&id=D8F960C4FE5A7FE2034DBD5417E85C22FE53323A&thid=OIP.nDhOt8mY1mtYjZBYssykVgHaE8&mediaurl=http%3a%2f%2fimg.photobucket.com%2falbums%2fv146%2feeshnab%2fIMG_7288.jpg&exph=534&expw=800&q=np205+rear+torque+mount&simid=607987245550669041&selectedIndex=25&ajaxhist=0
Logged
JK Buggy, 6.2, 400, Atlas, 14 bolts, 43's
penn
Offline Offline
« Reply #14 on: April 16, 2019, 09:57:36 AM »
I too run a J&w bell housing.
Logged
30th6
Offline Offline
« Reply #15 on: April 16, 2019, 10:28:37 AM »
My trans guy is supplying the case and swapping all the parts for $150.
If it breaks again after the mount changes I'll get that bell housing. Only had 2 bolts holding it in.
It might have broke before I put the engine cage on, I was driving it around without the engine cage around the yard and may have stress the trans and broke it
Logged
30th6
Offline Offline
« Reply #16 on: April 30, 2019, 06:17:09 PM »
So I just realized the spacer in the crank for the tq converter to sit in was to long. It also broke my flywheel. I bet that was a part in breaking the housing . I got a new trans ready to go in
Logged
zukimaster
Offline Offline
« Reply #17 on: April 30, 2019, 06:45:15 PM »
Why did you not just put a J&W bell housing on it?
Logged
30th6
Offline Offline
« Reply #18 on: May 01, 2019, 02:29:47 AM »
It needed a refresh on it anyway, and I came out cheaper getting it rebuilt with a new case
Logged
Rootar
Offline Offline
« Reply #19 on: May 03, 2019, 10:51:00 AM »
Lets see the new mounts! Remember you can use a rear 205 support (like this https://www.tmrcustoms.com/transfer-case-support-kit-np205 ) but it needs to be centered on its cross member as with the trans mount being single poly mounted at the center of its cross member.
Logged
Pages: [1]   Go Up
  Print
Jump to:
