Hardline Crawlers
July 21, 2019, 06:57:28 PM *
Pages: [1]   Go Down
  Print
Author Topic: 2016 1000 shift issue  (Read 1215 times)
jeeptj99
Offline Offline
« on: May 06, 2019, 05:51:28 AM »
So on my girlfriends 16’ 1000 rzr when you stop and it’s at the slightest bit of incline or even sometimes on flat ground you can’t get the thing out of park. Someone has to get out and rock it while someone tries to shift it. It feels like the trans wont let it shift out. Is there a fix for this? I know nothing about these things but trying to help her out.
Logged
Travis
Little tires, big heart
I feel the tires perform best at what can best be described as the jiggle equivalent to that of a middle aged mother of two's ass. Just right.  Cougar
ibrokeit
Offline Offline
Brock Higdon- Auburn, AL
« Reply #1 on: May 06, 2019, 02:11:45 PM »
I don’t know the fix for the actual problem but it is common.
Buy a “spring brake thingy”. That’s literally what it’s called. Like a parking brake. Apply it before shifting to parking.
Logged
ridered3
Offline Offline
Not Rigless
« Reply #2 on: May 06, 2019, 02:24:58 PM »
^ What he said.  https://www.google.com/search?source=hp&ei=TKXQXManI-yg_QaW05lQ&q=rzr+parking+brake+thingy&oq=RzR+Parking+Brake&gs_l=psy-ab.1.2.0l3j0i22i30l7.366.4244..6832...0.0..0.124.1763.10j8......0....1..gws-wiz.....0..0i131j0i10.YsJJI2uvawg
Most RzR models didn't come with any form of a factory parking brake.  So the lack of shifting is a common issue.
Busted Knuckle used to carry a $60.00 spring operated parking brake, but I don't see it on their website anymore.  Which is a shame since A) I could use one and B) how to use the parking brake was modeled by Burkey in Crocs, so something that should never leave the internet...
Or just try out this video:
Free Polaris RZR Parking Brake
Logged
Tent: Freespirit Recreation RoofTop Tent (RTT)
Tow: 12' Ford F250; 4x4 w/ 6.7 Powerstroke
Toy: Polaris Gayzr 800s
Toy Hauler: 2000 Fleetwood Wilderness 26' Footer
Rockvale, TN
jeeptj99
Offline Offline
« Reply #3 on: May 07, 2019, 11:30:27 AM »
Try that and see how it works then show me because I cant get the video to work.
Logged
Travis
ridered3
Offline Offline
Not Rigless
« Reply #4 on: May 07, 2019, 11:55:25 AM »
Still works on my end of things,but basically he sticks an allen wrench in between to top of the brake pedal and the brake mounting area.  Will send you some pictures this weekend when I'm back home.
Logged
Rockvale, TN
ridered3
Offline Offline
Not Rigless
« Reply #5 on: May 13, 2019, 07:11:22 AM »
Messed around with this over the weekend and discovered that using an allen wrench wouldn't work for me, since there was too much of a gap between pedal and pedal mount.  So instead I found a misc bolt in a drawer that worked quite well.  I can reach down underneath the steering column and easily put the bolt between the brake pedal and pedal mount.
Previously our RzR would rock 6-8" when in Park.  With the bolt installed, the RzR rocks 1-2" when in Park.  No idea if it will work on the trail, but it worked good in the garage.
Logged
Rockvale, TN
ridered3
Offline Offline
Not Rigless
« Reply #6 on: May 29, 2019, 05:35:30 AM »
Follow-up on this after a trail ride.
Typically I try to find somewhere flat-ish or somewhere to hang a tire on in order to park and not have to worry about shifting our of Park.  Had a couple of instances down at AOP where that was not an option, so tried out the bolt method.  Seemed like it worked pretty good.  No issues shifting out of Park on uneven ground/parking situations.
So for the low cost of a free misc bolt out of the toolbox, I am pleased with the bolt parking brake setup.
Logged
Rockvale, TN
Pages: [1]   Go Up
  Print
Jump to:
