For Sale Lifted Dually and Custom Gooseneck 20+5 for Sale (will separate)
corey_moon
Member
As the title states, I have a 2015 Platinum Ford F-350 with an 8" lift for sale with a 20+5 14K gooseneck that was custom built for the truck and it's lift. The gooseneck was built extra tall so that it rides level. The bottom of the gooseneck as it goes over the bed is about 76" off the ground and the hitch is at about 44". The gooseneck can't really be towed very well by a stock truck, unless an extended coupler was built for it. I will separate the two, but need to sell the trailer first. Titles in hand for both.
I can be reached by phone or email at (832) 972-6666 or [email protected]. I will be out of the country February 1st-18th. Would like to get $38,000 for the truck and $4,500 for the trailer.
Truck Specs
2015 Ford F-350 Platinum Dually
174,XXX Miles
Brand new Ford OEM transmission with 3 year Ford warranty as of July 2023. Have warranty paperwork
Brand new Charge Air Cooler July 2023
Mishimoto Cold Side Delete
New front brake pads July 2023
8" Fabtech Lift with 7" Deaver Soft Ride Rear Springs and 1" Block
Dirt Logic Coilovers and Steering Stabilizers.
Firestone Ride-Rite Airbag set up plumbed to Viair Compressor and 2 gallon tank
Air chock for tire filling under rear bumper
4:10 gears
22" Fuel Hostage Wheels
37"x13.50 Nitto Trail Grappler MTs
PPEI Tunes loaded on EZ Lynk SOTF deleted at 15,000 miles
S&B Cold Air Intake
Amp Running Boards
B&W Gooseneck Hitch
Ceramic Coated with Ceramic Pro (due for an update of the topcoat)
I've owned the truck since it had 2,000 miles and it's a great truck: I am just wanting to downsize to something smaller as I am not currently towing
Have a 20' gooseneck trailer that was custom built for the truck that can go with it for another $4,500
Known Issues: the Auto 4x4 doesn't work (minor vacuum leak somewhere), one Rigid Side Shooter is going out, and the XPEL clear wrap on the passenger side dually flare is starting to crack
