1977 fj40 crawler project
fj40southernil
New Member
Up for sale is my project 1977 fj 40 it does have a clear title. That was a big influence on starting this build. Life has thrown a few curve balls lately and it has to leave not enough time to finish it.
Drive train-
1972 Dana 60 king pin front axle 5.13 gears welded up/ trussed from crawl works customs.
1972 14 bolt 5.13 gears welded up/ trussed from crawl work customs
New small block Chevy reman-new headers with new Holley sniper injection sitting on top of high rise aluminum intake.
700r4 monster with rmvb
205 Chevy transfer stock internals
Suspension
All new 7075 upper an lower aluminum links with inch and a quarter chrome Molly heims with 1" bolts the brackets are also from crawl works. Front and rear
4 new rad flo coil overs 16" not sure on the spring rate as they were purchased with this rig when I bought it.
2 new 4" bumps with cans not mounted
Chassis
It has been complete rhino lined top to bottom the metal work underneath is also new no rust anywhere on this rig.
New led lighting though out
New painless wiring harness
New transmission cooler with electric fan
One orbital vale/ factory fj steering box
To do list
The brakes need hooked up
The fuel injection needs finished every thing is there to do the Holley sniper kit is a master it has not been started with it.
I have a set of mrwb 12 wide 32 bolt beadlocks to go with the sale no tires
Seats need mounted I have three new seats just need mounted
Transmission tunnel in cab needs built for a consol.
I have multiple other things for this rig that I would be willing to let go. Please text 618-841-9585 located in southern Illinois.
10k obo
Pictures
