Rock Crawling Forums
Anybody loose boost when climbing?
Reply to thread
Message
<blockquote data-quote="skipnrocks" data-source="post: 709531" data-attributes="member: 3166"><p>Ok so i jacked the rig up thinging if it had loose bearings there may be a wobble when I get climbs that would be opening up the piston causing it to go to the floor till you pump it back in. I had a loose king pin but since that affects both the caliper and rotor I didnt figure that could be it? </p><p></p><p>I hate to throw parts at it by just swapping out the MC but im running low on options? </p><p></p><p>Is there a definitive way to test it?</p></blockquote><p></p>
[QUOTE="skipnrocks, post: 709531, member: 3166"] Ok so i jacked the rig up thinging if it had loose bearings there may be a wobble when I get climbs that would be opening up the piston causing it to go to the floor till you pump it back in. I had a loose king pin but since that affects both the caliper and rotor I didnt figure that could be it? I hate to throw parts at it by just swapping out the MC but im running low on options? Is there a definitive way to test it? [/QUOTE]
Verification
Post reply
I am moving to Tennessee
Latest: Blackbeard
Yesterday at 4:06 PM
Monday at 11:55 AM
Friday at 4:44 PM
Friday at 7:47 AM
