Rock Crawling Forums
Anyone ever built a Floating Boat Dock?
Reply to thread
Message
<blockquote data-quote="leeman1790" data-source="post: 297467" data-attributes="member: 652"><p>I helped a little bit with my neighbors a long time ago. It is two stories, probably 25ish x 25ish. It is held afloat by black plastic rectangle things, pretty sure they are foam filled. He has a pontoon boat that parks in the center with walk arounds on each side, you can also unhook the dock from the floating walkway/poles it is </p><p>attached to. When unhooked you can motor around the lake using the pontoon as the pusher, basically a big party barge. That's my favorite part. I think over the years there have been 1 or 2 of the floats start to sink, but other then that it appears maintenance free.</p></blockquote><p></p>
[QUOTE="leeman1790, post: 297467, member: 652"] I helped a little bit with my neighbors a long time ago. It is two stories, probably 25ish x 25ish. It is held afloat by black plastic rectangle things, pretty sure they are foam filled. He has a pontoon boat that parks in the center with walk arounds on each side, you can also unhook the dock from the floating walkway/poles it is attached to. When unhooked you can motor around the lake using the pontoon as the pusher, basically a big party barge. That's my favorite part. I think over the years there have been 1 or 2 of the floats start to sink, but other then that it appears maintenance free. [/QUOTE]
Verification
Post reply
Friday at 3:12 PM
Daves Offroad Supply
Latest: Daves Offroad Supply
Wednesday at 10:52 AM
Vendors
B
Latest: Bebop
Tuesday at 7:19 PM
P
YouTube of the day
Latest: paradisepwoffrd
Monday at 8:21 AM
Cash LeCroy Illness
