Rock Crawling Forums
Ask someone that knows more than you
Reply to thread
Message
<blockquote data-quote="bradzuki" data-source="post: 476612" data-attributes="member: 2585"><p>When we split the thinner pieces, we laid it in some 3/8" thick angle iron and put 5 or 6 heavy tacks along the bottom to hold it in place. Using the hand torch on the plasma, we'd bounce around cutting slits about 18" long but not connecting them. We'd leave about 1/4" of material between each cut. After that cooled we came back with a cut off wheel and cut the 1/4" that we left and also the tack welds. They came out as close to perfect that you could get with this set up.</p><p></p><p>There is no way this will work on the thicker tube though, warping and the clean up would be too much. That's just too much heat to put into it.</p></blockquote><p></p>
[QUOTE="bradzuki, post: 476612, member: 2585"] When we split the thinner pieces, we laid it in some 3/8" thick angle iron and put 5 or 6 heavy tacks along the bottom to hold it in place. Using the hand torch on the plasma, we'd bounce around cutting slits about 18" long but not connecting them. We'd leave about 1/4" of material between each cut. After that cooled we came back with a cut off wheel and cut the 1/4" that we left and also the tack welds. They came out as close to perfect that you could get with this set up. There is no way this will work on the thicker tube though, warping and the clean up would be too much. That's just too much heat to put into it. [/QUOTE]
Verification
Post reply
Yesterday at 3:12 PM
Daves Offroad Supply
Latest: Daves Offroad Supply
Wednesday at 10:52 AM
Vendors
B
Latest: Bebop
Tuesday at 7:19 PM
P
YouTube of the day
Latest: paradisepwoffrd
Monday at 8:21 AM
Cash LeCroy Illness
Sunday at 2:58 PM
