Rock Crawling Forums
CPI injection I've had it! need help
Reply to thread
Message
<blockquote data-quote="87_bigbadzuk" data-source="post: 404917" data-attributes="member: 7012"><p>Got a gauge on it. Key on engine off pump running I set it to 55 psi. Put it back together and started it. It drops to 40-45 and if I give it gas it jumps to 55. If I punch it it stumbles till the pressure comes up then picks back up. I guess I need to check voltage at the pump At idle. I had jumper wire when I set it so could be the difference.</p></blockquote><p></p>
[QUOTE="87_bigbadzuk, post: 404917, member: 7012"] Got a gauge on it. Key on engine off pump running I set it to 55 psi. Put it back together and started it. It drops to 40-45 and if I give it gas it jumps to 55. If I punch it it stumbles till the pressure comes up then picks back up. I guess I need to check voltage at the pump At idle. I had jumper wire when I set it so could be the difference. [/QUOTE]
Verification
Post reply
Yesterday at 8:40 PM
C
Latest: chaplinfj60
Thursday at 9:54 AM
Jimmy Smith Rockbouncer 383 Stroker
Latest: Zjman
Wednesday at 10:15 AM
A
Jeep Wrangler Sahara Wheels
Latest: A.C.
Tuesday at 9:56 AM
B
Latest: Bebop
Monday at 8:52 AM
