Rock Crawling Forums
Engine coolant temp warning light
Reply to thread
Message
<blockquote data-quote="TBItoy" data-source="post: 438204" data-attributes="member: 1384"><p>usually a temp sending unit will work better if it is submerged in fluid, so you need to find another spot to put your sending unit (rather than using a T).</p><p></p><p>There should be another place on the intake to put a sending unit (or a boss that hasnt' been drilled/tapped yet)</p></blockquote><p></p>
[QUOTE="TBItoy, post: 438204, member: 1384"] usually a temp sending unit will work better if it is submerged in fluid, so you need to find another spot to put your sending unit (rather than using a T). There should be another place on the intake to put a sending unit (or a boss that hasnt' been drilled/tapped yet) [/QUOTE]
Verification
Post reply
Friday at 3:12 PM
Daves Offroad Supply
Latest: Daves Offroad Supply
Wednesday at 10:52 AM
Vendors
B
Latest: Bebop
Tuesday at 7:19 PM
P
YouTube of the day
Latest: paradisepwoffrd
Monday at 8:21 AM
Cash LeCroy Illness
