Fuel mileage
Yeah, no kidding! I understand fully about a full tank and going the distance, and it will not be that good when stopping and starting, but that was as far as I have driven it at one time, and it only used 3.66 gallons driving easy on the interstate, coming from a 454 dually getting about 9mpg, I was amazed.
my 2014 duramax 2500 crew cab short bed SRW 4x4 stock motor, no deletes or tunes, leveling kit and 275/65R20 (34") tire gets about 13.5 - 14 mpg city driving (decent bit of sitting in traffic), 20ish highway mpg at around 75-80mph (ranges 19-22 depending on headwind and how hilly it is), and towing a standard wood deck 16 foot trailer with my buggy on it (~4000lbs buggy) at about 75mph it gets 12-13 mpg.
No inflated numbers and all hand calculated
Just for numbers sake...
I hand did mine on my hand and get 48.3764 mpg with this set up. I have to run 2.75 gears with all the horsepower the big C makes. Oh and we run around 85mph unless in cities then it's 78.3.
Sent from my XT1635-01 using Tapatalk
Re: Re: Fuel mileage
All that is more believable than the fact that you don't have your tow mirrors turnt up? Or am I just looking at it weird?
Or have a transmission installed along the way. :rolf:
Slow down to 70 and it starts making fuel?
Just a thought but maybe the pump was out of wack and was supplying more fuel than it registered. I stopped at a pilot one time and as soon as i flipped the lever up and turned to put the nozzle in, diesel started running out at a decent stream before I'd ever pulled the trigger. If I'd of had 45 minutes to waste I could have filled up for free.
The best I ever got in my old lbz was about 25mpg and that was from a speed limit cruise down the interstate with as minimal throttle as possible. I have a new 2018 duramax now and 21mpg is the best 50 mile average I've seen in the first 10k miles. It tends to avg around 16.5 on the interstate.
