ftoy516
NOT PART OF THE HERD!
i have a gm 10/12 si alternator on my buggy that has been working fine, but long story short i had to rewire some things because of an issue with my kill switch....
so i fixed the issue with the kill switch and this lead to the alternator feeding power back into the ignition (thus the buggy would not turn off) so i tried to find a solution to the problem and decided to wire a Diode into the circuit. i wired the Diode inline with the #1 (exciter wire) terminal and this allowed the kill switch to turn off the buggy and the Diode stopped the power from getting to the Ignition....HOWEVER i then noticed that the Alternator gauge showed that it was NOT charging the buggy...
i then stared to test it with my meter and it showed that it was indeed not charging (which it did before) so i took some jumper wires and put on terminals #1 and #2 to see if it would charge without the Diode....and it Charged with the jumpers and without the Diode in the picture, but that way does not allow the buggy to kill out which is why i went with the Diode in the first place.
the #1 (exciter) wire with the Diode gets 12v from a terminal block that is down stream of the kill switch. i also tried pulling 12v power straight out of the fuse box to terminal #1 instead of the way i have it and nothing changed when i went that route. the meter showed it was not charging that way as well...
the #2 wire (voltage sensing) wire gets 12v at a bus bar which is where the alternator batter wire is getting power as well.
12v is not something i know a whole lot about...and i just thought i would ask some of you guys to see if i may be missing something or if anyone has any experience with this type of set up.
any ideas or help would be greatly appreciated
