oil cooler with hydroboost and full hydro?
skipnrocks
Billings Montana
I have a cooler plumbed in for my power steering fluid. I have full hydro and mustang hydro boost. From what I read I don't need a separate cooler for the hydroboost since little fluid actually passes through to return to reservoir. SO it seems I should just run it back to reservoir and let the bulk fluid that runs through the orbital handle the cooling I just wanted to see if you would agree with that.
Yes 100% You get the most return oil through the orbital valve that is what you want to cool. I like tube and fin coolers on steering because they flow well. Others may disagree.
