Rock Crawling Forums
Propane ????
Reply to thread
Message
<blockquote data-quote="altfuel1991" data-source="post: 365960" data-attributes="member: 1211"><p>If at all possible mount the vaporizer outlet pointing downward so the heavy ends(molecules) in the fuel will flow out with the rest of the vapor. When propane is heated above 180 degrees the mixture can crack which means the oily components can separate and have a harder time flowing out of the vaporizer. If the heavy ends do not flow out with the rest of the fuel they settle in the housing and turn into an oily, waxy substance. We see this mostly on forklifts and trucks over a long period of time.</p></blockquote><p></p>
[QUOTE="altfuel1991, post: 365960, member: 1211"] If at all possible mount the vaporizer outlet pointing downward so the heavy ends(molecules) in the fuel will flow out with the rest of the vapor. When propane is heated above 180 degrees the mixture can crack which means the oily components can separate and have a harder time flowing out of the vaporizer. If the heavy ends do not flow out with the rest of the fuel they settle in the housing and turn into an oily, waxy substance. We see this mostly on forklifts and trucks over a long period of time. [/QUOTE]
Verification
Post reply
Latest: xjcrawler
41 minutes ago
Latest: baldduck74
Yesterday at 4:22 PM
Cash LeCroy Illness
Yesterday at 1:02 PM
Latest: Sawzall
Saturday at 11:03 PM
Coalmont TN OHV New Park info
Friday at 3:48 PM
Propane ????
